Hackaday.io Hackaday.io
Sign up Log in
UR5 Pick and Place and Drawing
I worked in a group to use Inverse Kinematics and resolved rate control to complete a pick and place and drawing task with a UR5.
nyeli-kratzNyeli Kratz
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
367
0
2
1
Team (1)
  • nyeli-kratzNyeli Kratz
Join this project's team
  • UR5 Blue Jay Drawing
completed project
Software
UR5 MATLAB
This project was created on 01/07/2023 and last updated 2 years ago.
Description
This project utilizes Matlab's ROS toolbox and Robotics System toolbox to control a UR5 robot arm. The user sets an initial position for the block and then the desired final position of the block within the UR5's workspace and then the robot picks up the block and moves it to the desired location. We accomplished this task using inverse kinematics, resolved rate control, and transpose jacobian control.
For our extra credit task, we used our inverse kinematics control system to draw any imported JPEG image.
Details
Files
FinalProjectReport_TEAM3_ CV_KK_NK_SY_SG.pdf
This report describes our Matlab alogorithms used to complete the tasks.
Adobe Portable Document Format - 557.40 kB - 01/07/2023 at 16:50
Preview
Log In/Sign up to comment
Sign up with Github
OR
Software framework for creating robotic control programs
Project Owner Contributor
The Robby Framework
lee-phillipsLee Phillips
The Aerobox is a tiny, ultra-portable, simple soft robotics control system.
Aerobox - A Soft Robotic Control Box
aidan-leitchAidan Leitch
Levitation of a small magnet with an electromagnet. Made to learn more about control system and PID.
Magnetic Levitation with PID Control
noelNoel
The 2016 Hackaday Prize
A surveillance robot that also could control the devices around it
Surocon (Surveillance Robot and Control Center)
hendra-kusumahHendra Kusumah
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "UR5 Pick and Place and Drawing", please tell us the reason.
Send message
Remove Member
