1USB to TTL
USB to TTL <-> SBC connection
GND <-> GND
+5V<-> VBUS
TDX <-> RXD
RXD <-> TXD
2JTAG configuration - SOF file
During JTAG configuration Micro-USB cable should be connected to FPGA board connector as shown above. You can see all the eight LEDs are turned ON after successful configuration using SOF
3In-System Memory Content Editor - PROG (8k ROM)
We can easily verify the ROM content after successful configuration of FPGA using In-System Memory Content Editor
4In-System Memory Content Editor - XRAM (4k RAM)
We can easily verify the XRAM content after successful configuration of FPGA using In-System Memory Content Editor
5Confirm the ROM version and program the POF file into FPGA
We can see the "MCS-BASIC-52 V1.31" at the end of 8k ROM memory as shown above
6TeraTerm
Install TeraTerm or Putty. Run the application. Select the COM port and default baud will be 9600.
7Hit the SPACEBAR!
After hitting the spacebar the following message should appear on the screen.
*MCS-BASIC-52 V1.31*
READY message
Now we can write any application using BASIC-52
8PRINTING ON THE SCREEN
9BIGGER AND LONGER
108 LEDs control using PORT 1
mit41301
