Covers designing, building and programming of hexapod robot from scratch
Have you considered using spring loaded joints with "muscle wire" to actuate? I think it would be more interesting but if you use too much then it will be super slow.
mechatronicproject10
Sean Hodgins
Arnab Kumar Das
Boian Mitov
Yes, delete it Cancel
You are about to report the project "TAS Hexapod Robot Open Source Project", please tell us the reason.
