Working Prototype!
03/05/2023 at 20:34 • 0 commentsI have my first two prototypes that are functioning and working well. The way I have configured the circuit you press the button and the LEDs stay on for about 43s (if the resistor and capacitor were perfect). You can of course make it longer with a larger resistor or capacitor in the timing circuit.
The main issue with the last iteration is that the footprint for the push button switch was done wrong so that the trigger pin was always pulled low causing the circuit to always be triggered.
Enjoy the demo video below:
Second Build
01/20/2023 at 22:11 • 0 commentsToday I built the second iteration of my timing circuit. It turns out a problem I was having with my first circuit still exists with this circuit because that has to do with a misunderstanding of how the tactile switch I'm using works. I thought the big separation between two prongs meant that the two prongs on one side were connected, but it turns out the long way is how they were connected. Not sure if that made sense but hopefully the attached photos will help.
This first working build was made by soldering jumper wires to the switch so that I could put them where they are supposed to go.
I also had two capacitors malfunction on me and I am not sure why, but it could be because my soldering iron gets too hot.
Now I will go and fix up my schematic for my next order and take this as a lesson to triple-check components.
Kody Alan Rogers
