Schematic
02/01/2023 at 09:24 • 0 comments -
Example of Pascal code
01/31/2023 at 12:54 • 0 commentsThis is pretty much what I found in my archives when searching for the source code. It looks like a clear experimentation phase since it's obviously not optimized. It also has a lot of repetition in it, but by the looks of it, it should still work.
About working... Some people might ask what it takes to restart this robotic arm today and if this code can still run on some machine. The answer is simple: I don't know. Maybe Pascal can still be installed on some machines in compatibility mode. Maybe there are some desktop units out there still having LPT ports. Maybe one can run this in a Windows98 virtual machine? I never tried usb to LPT cable adapters, but maybe they work. Anyway... here's the code:
