Hardware
Architecture
There is 12 servos for 4legs ( 3 servo / leg). I put a microcontroller for each legs to control 3 servos. The timing pulse(20ms) is outputed from main MCU (SAMD51) to synchronize all servos.
The power source of servo motor is from DCDC. The output voltage of DCDC is controlled by main MCU. The range of output voltage is 5 V to 6.5V.
Main MCU connected to Raspberry Pi zero via USB.
what is the material? what a cool design
