Dispensing with the oscilloscope, ac power supply, and all those wires, the Ardupus does all that the Octopus did, and more.
Freestanding, easy to build, and with more features than your old Octopus, the Ardupus breathes new life into this timeless piece of test equipment.
Presented here in several forms, the choicest being the dual window version, giving side by side signatures of componetry. All electronics sit on a shield between Arduino and display.
Simpler, Mega based versions are included, and offer a basic Ardupus, but still a vast improvement on the old ac powered Octopus.
Full construction notes, circuit, software,and simulations are on an accompanying pdf at excelworks.info, on my Arduino page. This project will not disappoint.
320x480 TFT currently at https://www.ebay.com.au/itm/263669828184?hash=item3d63f24a58:g:WsQAAOSwxUlkPKTx&amdata=enc%3AAQAIAAAA4Fs5htITRu6O%2FDXiOS2Hby5MKro5vn6PHD61CC9CooniPGGS2v1nWraPXRIVNnqRJEN3ulp41AAqzWLoeD1hJ4XDeb9%2BVX4Ae9WtP%2FuGFekdzPOMpENkzcnpH9CDCbSMYd8B9JphUNF0%2FHve5P%2FSCSM0hPCEK75Wcdg1z34ta2S5%2BhgBGb17zWCY5MzgKvFkoRa4HVQhxueUb37sX0i8rX3uevTvTG8Clx2rVIQvS9ps%2FponCSnfzI2eCg7b3b2UzKGyZstXKLPAKvI80%2FzAHeYU1PF6h16Z0rmH1FolkZYA%7Ctkp%3ABFBMwIa15K5i
Other TFT is as as previously noted on 3/5/2017
Full build instructions per PDF download at my website, excelworks.info, on the Arduino page.
If you cannot find the 240x320 TFTs, then you will have to re-code display to suit what you can currently buy.
2. "ARDUPUS" 320x240 MEGA Rev1", Rev2, and Rev3 codes use a 240 x 320 marked "M3208A" atop of a "LCD Mega Shield V1.0" Driver is UTFT myGLCD(SSD1289_8, 38, 39, 40, 41), as uncommented in code.
You should be able to adapt any suitable display for these versions.
Miguel
