A breath of new life for a classic piece of test gear.
The “Octopus” morphs into the ARDUPUS
Muchas gracias por su respuesta, buscare el display que me dice y en caso de no encontrarlo, buscare uno que tenga esa resolución y a probar si va.
Muy buen proyecto, me podia decir un display equivalente al que usted puso? A ser posible para las dos resoluciones.
Un saludo ......... Miguel
Desde Salamanca España
1. "ARDUPUS_320x240_MEGA_Rev0" and Rev00 versions
Tinxiworld no longer has a listing for the 320x480 I used.
However, this appears to be identical:-
http://www.ebay.com/itm/320-480-3-2-inch-TFT-Color-LCD-Display-Module-for-Arduino-Mega2560-R3-/252726803379?hash=item3ad7b0fbb3:g:4aoAAOSw2xRYfJwq
It uses a different driver to the original, ILI9481 which is not listed in my code.
2. "ARDUPUS" 320x240 MEGA Rev1", Rev2, and Rev3 codes use a 240 x 320 marked "M3208A" atop of a "LCD Mega Shield V1.0"
Driver is UTFT myGLCD(SSD1289_8, 38, 39, 40, 41), as uncommented in code.
You should be able to adapt any suitable display for these versions.
Miguel
320x480 TFT currently at https://www.ebay.com.au/itm/263669828184?hash=item3d63f24a58:g:WsQAAOSwxUlkPKTx&amdata=enc%3AAQAIAAAA4Fs5htITRu6O%2FDXiOS2Hby5MKro5vn6PHD61CC9CooniPGGS2v1nWraPXRIVNnqRJEN3ulp41AAqzWLoeD1hJ4XDeb9%2BVX4Ae9WtP%2FuGFekdzPOMpENkzcnpH9CDCbSMYd8B9JphUNF0%2FHve5P%2FSCSM0hPCEK75Wcdg1z34ta2S5%2BhgBGb17zWCY5MzgKvFkoRa4HVQhxueUb37sX0i8rX3uevTvTG8Clx2rVIQvS9ps%2FponCSnfzI2eCg7b3b2UzKGyZstXKLPAKvI80%2FzAHeYU1PF6h16Z0rmH1FolkZYA%7Ctkp%3ABFBMwIa15K5i
Other TFT is as as previously noted on 3/5/2017
Full build instructions per PDF download at my website, excelworks.info, on the Arduino page.
If you cannot find the 240x320 TFTs, then you will have to re-code display to suit what you can currently buy.
