Small code update, and added a website example for XMLHttpRequest
01/20/2024 at 17:42 • 0 commentsI updated the code on github so that it will give separate error messages. Now, it will give an error if the filename is bad, and it will give a separate error if the pico can't open and send the file (usually caused when the file is too large).
I also added "led_website.html". This demonstrates how to use XMLHttpRequest to set the LED on the raspberry pi pico, and has a timer that automatically queries the status of the LED to display on the website without having to refresh the page.
