This was supposed to be written on the same day as Log1 but I didn't have the time. At least I can now also talk about the specific filtration system I ended up buying.
Research into carbon filters in general
So I started some research and it was suggested to get a carbon filter that had at least one full air chainge per minute.
2.4 x 1.2 x 2 = 5.76 m^3 => 203 ft^3
There's loads of fan efficiency debuffs along the way though, so my aim was 350 CFM (cubic feet/minute)
I thought that a human would require more ventilation than small plants, but it seems that the actual requirements are much lower:
I'm skeptical because I have a small air purifier that claims 6 months filter life, but the filters were spent within 4 weeks. However, I was researching the Nevermore when researching for the #SecSavr Suspense [gd0105] and these kinds of consumer air purifiers likely don't have enough activated carbon / charcoal to last very long.
Still though, spending (as I'd soon find out) £40 - £50 on a massive filter that lasted 6 months is still better than 1 small filter / month costing >£9 that likely only effectively filters for half the time. Also note that those 1 - 2 year expectations are with the filter running 24/7 and I wasn't running my small purifier 24/7.
Researching purchaseable options
The first filter I found was from Vivosun because I had just found thier £120 tent and wanted to see what else they had.
The 6" wasn't in stock when I first saw this listing, but it was the next day for £65.
The reason why I went for the £82 kit instead of the £65 kit is because I did some looking around on filter / fan prices and that £65 was a bit suspicious. The cheapest 150 x 500mm filter was £40 and the cheapest 6" fan (the red-blade one) was £41. I looked into the filters each kit seller sold as individual listings (because they probably don't stock filters specifically for a kit and a different filter for refils) and the £65 seller never mentioned anything about "Australian Mined RC412 activated carbon". I've seen that specific carbon mentioned on so many listings that I thought it was redundant or just an industry standard. Lastly, the £65 kit only did 150 x 300mm (which is acceptable for the price difference).
I also found out about fan speed controllers:
Trying the system
I was hoping to at least get a room purifier going, since this setup should be able to change the volume of air in my entire room over 10 times an hour. Unfortunately the indifferent universe said NOPE to my hopes.
I opened the electronic box and didn't really see much of interest other than a 1.5uF 450V capacitor. The symptoms sounds like this could be faulty: https://airflowacademy.com/ceiling-fan-capacitor-bad-signs/
Seller has issued a recall of the fan
