Media
Music I mentally associate with this project
Navigation
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
Preface
[2023 - Feb 25]
So, unfortunately, projects like #Tetrinsic [gd0041], #T^2 TyMist [gd0138], #TaskPercent [gd0140] and #SecSavr Suspense [gd0105] will take many hours of continuous efforts before I actually see results. I'm doing 3 of those 4 projects so that I can make it faster and easier to complete projects; this is known as a "chicken and egg" problem. I actually need something right now that I can use to achieve a more focused and less distracted mindset so that I can work though all my projects/commitments at a consistent pace (rather than this boom/bust cycle you might have noticed in my projects).
First thing I did was buy some rather nice looking gripped "arthritis gloves" (2 pairs for £7) so that my fingers can hold out a bit longer whilst waiting for Tetrinsic -- and subsequently #Tetent TestCut [gd0139] -- to become a thing that exists. The gloves actually fit my hand and I strongly believe it's because the finger-ends are cut off. They certainly look all futuristic and hacker material which helps with mindset, as well as hopefully preventing finger strain.
[20 March 2023 update] - These gloves are nice for many things. Typing is not one of them. They seem to speed up fatigue due to the increased motion resistance.
Then I thought to myself about what I could realistically do to get a usable work-mode setup ASAP (under a week). I haven't read any articles about WFH setups, but I can imagine that doing everything from the comfort of your mattress is not recommended. (Oh yeah, I watched a CGP Grey video about this years ago.)
I thought of a tent tube / kid tunnel:
Well a tent tube, but wide enough for a table, 180cm / 6ft tall ceilings and with reflective walls (like silver projector screen material). Inside would be a proper carbon filtration system and I'd figure out a lighting solution along the way. This sounds quite reasonable actually, because it's the non-portable version of TyMist.
[1 Mar Edit Start]
I have a feeling that my subconscious saw the below animation video on how Tilt-5 works (because I really like the soundtrack and made a loop) and eventually proposed this reflective tent idea.
This is because the first time I saw the animation (and before the small blue figurines made an appearance right on the soundtrack beat), my attention was captivated by the background:
As soon as I saw this, I immediately imagined Jeri Ellsworth (the CEO) working in Britain and sitting in an office away from any busy roads and just quietly working on this product as the overcast sky illuminated the white office walls. My reaction to that was "Wow that's a dream way to work! It's probably not the way she actually works, but that's a truly peaceful way to R+D for an unknown amount of time and actually enjoy the grind".
I don't enjoy the grind, which I define as the main part of any project or education development where you know you're going to be there day in and out slowly developing but it doesn't feel like actual progress is being made because the milestones are few and far between at this stage, like a plateau.
I've been trying to make the grind more enjoyable (or reduce the amount of time spent) for over 6 years now. Will this be the...
kelvinA
However, I think the dimension are actually for 1 segment and they're just showing that they're modular. I'd otherwise find it hard to believe that those 3 segments are 2.1m long.
This tent also has windows, which might be problematic or it might be possible to mount LCD backlight panels on the outside to give the illusion that the tent exists in the white pocket dimension.
Moving on...
My first idea was to start from the top and build downwards. Obviously that failed, so I quickly deconstructed...
I was thinking of some kind of motorised solution to get multiple light angles, but with prices like this, It's trivial to install maybe 3 - 5 LEDs and address them via a binary relay system (to guarrantee that only one fake sun is on at once). With this method, each LED only needs to have a single colour temperature whereby the LEDs on the ends have a warm colour temp (2500K) and the LEDs in the centre have a neutral temp (5600K).
There's 2 LEDs in this diagram above and those rays are probably parallel enough to look convincing. I should be working not looking up at the fake sky anyway, so it's not like I need the fancy light scattering to replicate the actual sky. The idea is kinda large though when you bring in a parabolic mirror that is large enough to make sense:
One listing was a bit of a mixed bag, but this listing has many identical screens such as the 13.3", the 10" and some 14" panels. This is ideal because then I can group these screens up to create a larger screen fixture. I'm also planning to address these LEDs so that I can have a low-budget version of Unbox Therapy's latest studio ceiling.
That area entered in is on overestimate too.
From my research, quite a few sources say that a carbon filter should be good for a year minimum. It is also straightforward to stretch this longevity to 2 years.
These kinds of things really do look cool.
I find this listing and am suprised that you get all this for only £53:
The 6" wasn't in stock when I first saw this listing, but it was the next day for £65.
Anyway, I eventually found and added the red-blade fan kit into my basket. The 300mm long filter was only £9 less and I thought that a longer filter would last longer and allow more airflow. Looking though the seller's store, I found the same listing but with a white-blade fan. The listings don't really talk about the fan in enough detail to pick on over the other, so I went with the white one because it looked better and a bit longer.
So it came in a massive box to the right (and the broken LCDs are in the box to the left, which I'll talk about in the next log)
Here's the fan. Note how it says 33dB at 3m distance. I think the red-blade ...
Then I spent 2-3 hours researching about ventilation (which I'll talk about in a different log) and I didn't want my lack of finds to delay the tent itself from arriving. At 3am (24th Feb) when I bought this tent, I didn't detect any issues with the green tubes or branding everywhere. I was just thinking "Yeah green and light grey are my branding colours anyway." and "WOW! This reflective texture looks much higher quality than the first one I saw!".
Before I went to sleep, I saw the below image and I quite like the industrialist look of the overhead filter and bright interior walls, looking at this from an office setup perspective.
So it was a new day and it took until maybe 6pm to realise I didn't mentally render the branding in any of my mental simulations. I look closer at the videos of the tent I can find to gather data, and soon I was thinking "Oh noh! There's "vivosun" every which way I'd look, and the green is the wrong shade." I can tolerate the green, but my worries have spiked because of all the interior branding.
There's an even cheaper tent that comes with rope rachets which are used to hang the carbon filter gear on the ceiling. Unfortunately, I looked into Gorilla Box tents and they also do the same branding thing that Vivosun does.
I found a listing that was kinda sketchy only because they took an image of another tent and poorly modified the image:
This tent was £108 after a coupon, which is one of the lowest I've seen so far. Well that is untill I'm scrolling through the search results and see this detailed render listing:
The tent is from Prodigy Tents, but in the process of finding that information, I found a
It looks like there's few things on the walls, such as extraction vents or rear mini doors (see the Vivosun tent) and the white beams blend in too, so I think this is a good solution with the Seuna one being a backup choice. The listing description also has everything I'm looking for in a tent:
Starhawk
neohackerjd
