Compared to the original version, this iteration offers several improvements:
* Raspberry Pi Pico 2 as the central unit
* Better audio quality using an I²S DAC and power amplifier
* An SSD1306 OLED display
* A rotary encoder for navigation and parameter selection
* Direct digital synthesis engine
* 9 instrument presets, plus 4 slots for user presets
* Filter cutoff frequency modulation controlled by device tilt
* Sequence looper with diatonic transport selector
* Volume control
* Extended note range
* Automatic storage and retrieval of last used settings
* Fewer components
Dodepan v2 also sports an amplified output with speaker disable. While it can work fine with some headphones, the signal from the audio jack must be attenuated before being connected to sensitive equipment. A resistor between 1.2KΩ and 4.7KΩ is recommended.
Turi
PixelCircuits
Ben Jacobs
CircuitMonster
Great project. Would like to build one myself
