This clock project was fun, but quickly exposed a fundamental flaw in the design. Incandescent bulbs simply have terrible life when constantly flashing on and off. (Now I know why lamp test used to be a big thing!) Eventually my stock of replacements was depleted.
Fast forward nearly 9 years and I was looking at why a LED bulb had failed. All the LEDs in it fell off the circuit board. Apparently they were glued on not soldered? But the LEDs still worked.
Looking at the LEDs I realized they would be the perfect sized and light color and output for an incandescent replacement.
I did have to modify my circuit to include a LED ballast resistor, but since only one element is on at any time, I only needed one.
If you'd like to learn more about this display, they can be seen here:
David Christianson
Ken Yap
Not that I'm aware.
