S221116_R050720_Z80.inoAdds support for 4 drives and others updates. Please see the following repo (created by Al Williams) for new tools, updates and info: https://github.com/wd5gnr/Z80-MBC (by Al Williams)ino - 165.09 kB - 07/07/2020 at 13:13 |
S111216.cTASM Assembler utility.C Source File - 1.21 kB - 05/15/2018 at 06:05 |
build.shLinux shell script to invoke TASM for WINDOWS (using wine) to assemble Z80 source code and produce a HEX file and a 'C' header file containing the code. Requires TASM 3.2 and wine. See the notes in the script (by Scott).x-shellscript - 1020.00 bytes - 05/14/2018 at 19:31 |
optiboot_m32-20mhz.hexAnyone wishing to overclock the AVR at 20MHz; OptiBoot HEX file for ATmega32/A running at 20MHz (by Scott).x-hex - 1.31 kB - 05/14/2018 at 18:29 |
optiboot_m32-8mhz.hexOptiBoot HEX file for ATmega32/A running at 8MHz (by Scott).x-hex - 1.31 kB - 05/14/2018 at 18:28 |
optiboot_m32-16mhz.hexOptiBoot HEX file for ATmega32/A running at 16MHz (by Scott).x-hex - 1.31 kB - 05/14/2018 at 18:28 |
S221116_R080518_Z80.inoAdds support for AVR @ 16MHz, Z80 @ 4 or 8MHz, 24FC1026 EEPROMS, definable I2C rate for the EEPROMS (up to 800KHz). See notes at top of file (by Scott).ino - 161.78 kB - 05/14/2018 at 04:16 |
MakefileMAKEFILE for use with SDCC under Linux. Should work for all SDCC 'C' projects. Supports the "data-loc=" and "code-loc" options (by Scott).makefile - 6.08 kB - 05/14/2018 at 04:14 |
iDisk-S250317_R090518.cBugfix. See top of file for details (by Scott).x-csrc - 14.80 kB - 05/14/2018 at 04:09 |
S221116_R100218_Z80.inoThe sketch for the Atmega32A (New release. Fix the "ghost RTC" bug: when there isn't any Virtual Disk (only Basic and Forth) the RTC clock was always incorrectly found).x-arduino - 167.93 kB - 02/10/2018 at 16:45 |
Z80-MBC PCB version - BOM.xlsComponent list and BOM for the Z80-MBC PCB version (see schematic and gerbers at: https://github.com/WestfW/4chipZ80)ms-excel - 28.50 kB - 10/17/2017 at 07:05 |
Z80-MBC - BOM.xlsComponent list and BOM for the Z80-MBC on breadboardms-excel - 28.50 kB - 10/17/2017 at 07:04 |
SRecord-custom.zipBatch and custom files for SRecord utility to make custom virtual disk images.Zip Archive - 16.06 kB - 05/29/2017 at 15:03 |
CPMtools-custom.zipBatch and custom files for CPMtools utility to make custom virtual disk images.Zip Archive - 4.48 kB - 05/29/2017 at 15:02 |
BIOS QPM271 - S080517.asmSource file of the BIOS for QP/M 2.71 with the RTC supportasm - 34.20 kB - 05/23/2017 at 19:19 |
QPM271_DiskPack.zipQP/M 2.71 Disk 0 imageZip Archive - 110.02 kB - 05/23/2017 at 19:18 |
CPM22 BIOS - S050217 R300417.zipSources for CP/M 2.2 and the BIOS (New version with the new BIOS supporting AUTOEXEC)Zip Archive - 40.30 kB - 05/02/2017 at 17:35 |
CPM22SYS_BIOS_S050217_R300417.hexDisk 0 system tracks only upgrade with CP/M 2.2 and the new BIOS supporting AUTOEXEC.x-hex - 14.92 kB - 05/02/2017 at 17:07 |
CPM22_DualDisklPack_v2.zipCP/M 2.2 dual disk system image (New version with the new BIOS supporting AUTOEXEC)Zip Archive - 184.36 kB - 05/02/2017 at 17:06 |
CPM22_SingleDisklPack_v2.zipCP/M 2.2 single disk system image (New version with the new BIOS supporting AUTOEXEC)Zip Archive - 101.35 kB - 05/02/2017 at 17:04 |
iDisk - S250317.ciDisk sourcex-csrc - 18.29 kB - 04/21/2017 at 15:28 |
iDisk - S250317.hexThe ready to use iDisk executable (.hex format)x-hex - 17.68 kB - 04/21/2017 at 15:27 |
ViDiT - S090417.cTest program for the Virtual Disk ModuleC Source File - 9.53 kB - 04/18/2017 at 14:10 |
A110417.pdfVirtual Disk Module schematicAdobe Portable Document Format - 22.98 kB - 04/13/2017 at 19:29 |
C_demo.zipTwo SDCC demo programs.Zip Archive - 1.25 kB - 02/09/2017 at 21:11 |
C_batch.zipTwo .BAT files for the SDDC toolchain.Zip Archive - 1.01 kB - 02/09/2017 at 21:10 |
S030217_crt0.s"crt0" source file for the SDCC compiler.Assembler Source File - 4.23 kB - 02/09/2017 at 21:08 |
4chipZ80-Eagle-PCB.zipZ80-MBC Eagle 2-Layer PCB and schematic made by Bill Westfield (Thanks Bill for sharing!). See his GitHub site for more info and updates: https://github.com/WestfW/4chipZ80.Zip Archive - 2.04 MB - 02/04/2017 at 17:30 |
S091216 R230117.asmZ80-MBC uLoader source fileasm - 3.70 kB - 01/31/2017 at 20:42 |
S260117.asmZ80-MBC iLoad source file.asm - 15.06 kB - 01/31/2017 at 20:42 |
BlinkDemo.asmThe Assembler demo program used in the video for the "automated" Assembler toolchain.- 1.80 kB - 01/31/2017 at 21:38 |
LoadZ80.ttlTera Term macro for the "automated" toolchain.turtle - 708.00 bytes - 01/31/2017 at 20:40 |
asmbatch.zipTwo .BAT files for the Assembler toolchain.Zip Archive - 1.03 kB - 01/31/2017 at 20:40 |
A080117 Kicad4.zipKiCad4 Project Files for the GPIO Expansion Module.x-zip-compressed - 22.96 kB - 01/22/2017 at 13:34 |
A080117.pdfGPIO Expansion Module schematic.Adobe Portable Document Format - 31.36 kB - 01/22/2017 at 13:34 |
A041116 KiCad4 Files.zipZ80-MBC KiCad4 Project Files.Zip Archive - 37.14 kB - 01/08/2017 at 09:12 |
basic.asmZ80-MBC Basic interpreter.x-asm - 196.93 kB - 01/04/2017 at 14:27 |
S121216.asmZ80-MBC uBIOS source file.x-asm - 8.63 kB - 01/04/2017 at 14:27 |
A041116 schematic.pdfZ80-MBC schematic.Adobe Portable Document Format - 101.42 kB - 12/17/2016 at 13:46 |
Just4Fun
