1Step 1
- PhatStats PC performance monitor & HardwareSerialMonitor Windows Client
by Rupert Hirst and Colin Conway
This project, assumes you have above average experience with Arduino, the IDE, compatible boards available and other related hardware.
___________________________
Project principles:
The HardwareSerialMonitor application detects the sensors of most modern PC graphics, CPU and motherboards whilst, also pooling windows hardware stats.
This data is then sent over a serial com port to an Arduino Microcontroller running the GnatStats Sketch and displayed on the OLED/TFT display.
Compatible boards:
- Wemos ESP32 LoLin32 / Lite / D32
- Adafruit QT-PY / Seed Studio XIAO Series
Seeed Studio SAMD21 MCU: https://www.seeedstudio.com/Seeeduino-XIAO-Arduino-Microcontroller-SAMD21-Cortex-M0+-p-4426.html
Seeed Studio RP2040 MCU: https://www.seeedstudio.com/XIAO-RP2040-v1-0-p-5026.html
Seeed Studio NRF52840 MCU: https://www.seeedstudio.com/Seeed-XIAO-BLE-nRF52840-p-5201.html
Seeed Studio ESP32C3 MCU: https://www.seeedstudio.com/Seeed-XIAO-ESP32C3-p-5431.html
ATMega 32u4 boards are more suited to (OLED) GnatStats . They do not have the required memory for (TFT) PhatStats.
Compatible Screens:
TFT : ILI9341 (SPi) 320x240 Pixel TFT Displays
Library and MCU core links are included within the Arduino sketch.
Notes:
- Plug the Arduino into a dedicated USB Port, try avoid using a USB hub. Timings can be critical to avoid garbled or corrupted screen info
- HardwareSerialMonitor was designed for dedicated GPU's . Your mileage will vary with Integrated Graphics
Guides:
technopat.net: Making an External Temperature Gauge
technopat.net: Additional Tiny Performance Monitor for a Computer
TallmanLabs: Phat-Stats ILI9341 TFT Display Hook up Guide
Whats the password for the ryzen file?
