PolyKybd (Displays In Your Keycaps)
Freedom at your fingertip.
Public Chat
Did you ever want to try a more efficient keyboard layout? Did you ever need another language on your keyboard? You have troubles remembering if F7 or F11 was the "step into" command for you IDEs debugger? PolyKybd to the rescue! It will just show you the keys function with little OLED screens in its keycaps!
Mechanical split keyboard with OLED displays in the key caps
It uses QMK as firmware for the keyboard and controls the displays via SPI and chained shift registers to address all displays separately or even all at once.
Other keyboard sizes might follow later (maybe a 75% version and a macro pad?).
There was a Hackaday post earlier about this project: https://hackaday.com/2022/10/17/poly-keyboard-has-screens-in-every-key/
Current Status
The HW development is almost finished. The firmware still needs further improvements as it is currently really just a work in progress to show what is possible.
However, the build guide is ready at https://github.com/thpoll83/PolyKybd#readme and I am happy to share that there is a pre-launch page on CrowdSupply in case you are interested in getting a kit: https://www.crowdsupply.com/polykybd/polykybd
Overview
More details will follow, please feel free to dig around in the git repos and ask questions.
  • ​ Remap your keys..!
    thpoll08/18/2026 at 10:49 0 comments
    Some time ago, I introduced an "Intl" key that lets me type the German ä, ö, ü and ß  (just hold the Intl key and press a, o, u or s) on a normal US layout (I indeed prefer how the wildcards are arranged over the German layout and no, I'm not a big fan of the US International Layout where e.g. ' + a makes á). For other languages, I can remap a to à, á, â, ã, ä, å, æ, ā, ă, ą, ȁ, ȃ, ǎ, ǟ, ǡ, ǻ, ȧ, ḁ, ạ, ả, ấ, ầ, ẩ, ẫ, ậ, ắ, ằ, ẳ, ẵ or ặ, so whatever variation you need. Press Intl and tap Ctrl and the number row turns into a picker of that letter's variations - 549 of them, every accented form encodes as a single character. Pick one, and that's what the key types from then on. Which works fine until a language with multiple variations of the same letter turns up. For example, there could be è, é and ê at the same time. To solve that, the variations can now be fully rearranged. Hold Intl, tap the new remap key, press the key you want to change, then press the letter it should host:
    Remapping q, j and ; onto e, then giving each its own accent - é è ê ë on four keys at once.
    So yes, also punctuation keys can host a letter now too. The layout decides: A key that isn't on the Intl layer simply never offers itself, which is how backslash excludes itself without anyone writing a rule.
    Here a small gif going through all variations:
    I hope that gives an idea of how the PolyKybd deals with special characters. Of course you can also use the layout for your own language and have the Latin character variation directly tied to a key. That works perfectly too.
    As always: firmware, PolyHost app, and docs are on GitHub.
    Best, Thomas
  • Running at 200MHz!!!!
    thpoll08/06/2026 at 09:11 0 comments
    A free speed bump, and firmware you can trust - two big things in this one.
    The PolyKybd now runs its RP2040s at 200 MHz instead of 125/133 - and no, this isn't an overclock. Raspberry Pi certified the chip for 200 MHz in 2025; In the keyboard space I haven't seen anybody interested, in QMK there is no support for that. I would say for 99% of all custom keyboards the standard 133MHz (I think via ChibiOS setup it in fact runs at 1225MHz) is enough. It just needs the core voltage nudged to 1.15 V, which the firmware now takes care of itself during boot. Fully in spec.
    I also have some real number what that brins for the PolyKybd:
    To summarize that:
    -️ Switching apps ~28% faster  -️ Keycap redraws ~30% faster - Doom noticeably smoother (yes, it's still in there) Here in percent values:
    Typing latency is identical. That's set by the USB frame rate, not the processor.
    I've been looking at this for long time and really satisfied that it turned out to be a painless (well there was some modification needed in platforms/chibios/bootloaders/rp2040.c, but is OK 😉) and a real improvement.
    Signed firmware!
    PolyKybdHost can fetch a firmware release and flash it for you. Lovely, right up until the obvious question: what stops something else on your PC doing the same thing? The update protocol always checked a CRC, but a CRC only proves the bytes arrived intact, not if the firmware is trustworthy (Well, I hope you trust me here).
    So the keyboard now verifies an Ed25519 signature over the image before it applies it, and releases are signed automatically by CI on Github.
    And it is deliberately not a locked platform! If you  build your own firmware, it still flashes, the keyboard just asks you to confirm it in person (the signed firmware will flash without confirmation). For that, every keycap goes dark except two: A(ACCEPT) on the left and R(REJECT) on the right:
    BOOTSEL/UF2 flashing is never affected either, so another path to flash your own firmware.
    Best, Thomas
  • Flashing both halves at once! And more ;)
    thpoll06/06/2026 at 10:13 0 comments
    This is the one I'm quietly proud of! Until now, updating meant pulling the repo or dragging a .uf2 onto both sides. The usual procedure: Boothloader mode, copy .uf2, wait for reboot, unplug and plug the other side, and repeat... no more!
    1: My host app now checks GitHub on startup and tells you when there's a new version for the host app and the firmware.
    2: The best part: The keyboard can now update itself in place!
    So it first downloads the firmware and puts it into a staging area in the flash memory on both halves. If the checksum matches, it applies the new firmware and reboots. So no more unplugging or bootloader mode, just click the update and ... done!
    It's brand new, so I'm still shaking out the edge cases — but the basic loop, "there's an update, click & done", works end to end. It took quite some time, and I made heavy use of AI assistance to find out the details for this feature, but now as it works, it is really cool.
    Hardware in the loop (HIL)
    Since this new firmware update feature needed a lot of actual testing on the hardware, I thought about a way to get automated testing on the hardware without me always pressing buttons and plugging in cables. As there is no complete RP2040 hardware emulator, I built a little hardware test station out of a Raspberry Pi 4 (in its own repo now). Both keyboard halves, so the real hardware is wired to it, and it can press the reset / BOOTSEL pads electronically — no fingers required (in case needed): https://github.com/thpoll83/polykybd-ctnd
    There is a GitHub action on the firmware repo, so that every push kicks off a cloud build, and the Pi takes that firmware, flashes both halves on real hardware, and runs a whole suite of HID tests on its own — while I'm off doing something else! It cannot yet verify the rendering (I need a camera) on the keys, but that is maybe the next logical step.
    New Uniode Emoji handling
    Before, I used 2 hard-coded layers for the most common Unicode emojis, but I wasn't that happy, as it left little room for expansion.
    There's now a single dedicated emoji layer: more than a thousand emojis, sorted into a dozen categories — Smileys, Gestures, People & Jobs, Animals, Nature, Weather, Food, Travel, Sports, Tools & Objects, and more. The top row of keys turns into category tabs (each tab shows the first emoji of its group), with arrow keys on the left and right to walk through multiple pages (for the bigger categories). Tap a key, and it types that emoji via Unicode input 🥰
    Not every emoji on earth 🌍 made it in yet, but the common ones are there — and adding more is now just a configuration thing (as long as the Noto Emoji font supports it). Some things do not make a lot of sense for me at this moment: E.g. skin tone shading and color stuff doesn't look great on b/w OLED displays indeed.
    On top of that, the pixel font organization got an overhaul — the ~99 hand-written font-conversion commands are now a single config file, and glyphs use full 32-bit codepoints (instead of 16-bit with shifts to keep the actual 32-bit codepoint in the 2-byte character). That's why growing the emoji/symbol set is a one-liner now instead of an afternoon.
    That's it - a bit more to show than last time. And as mentioned before, a lot of this came together fast thanks to AI pair-coding.
    Thanks for reading, and for the support 🙏
    Thomas
  • A few very busy weeks
    thpoll05/15/2026 at 13:16 0 comments
    Three repos, and a lot of commits. This one covers firmware, the polyhost software, and the font converter tool — all moving at the same time. Buckle up.
    Firmware: RGB Matrix Keys That Actually Feel Good
    This was just an annoying little detail I never had time to address: Holding the brightness or hue key now does what you'd expect: it repeats. There's a short initial delay before the repeat kicks in, and then it goes at a comfortable rate. The other change: adjustments no longer write to EEPROM on every single step. The save happens when you release the key. If you're holding it down, you're still deciding — no point wearing out the EEPROM mid-adjustment. With that, I introduced a wider EEPROM read/write cleanup. Only update what is needed, when it is needed :)
    Firmware: Suspension Fix
    This was the other little annoying detail: When suspending, the RGB matrix sometimes stayed on for the slave side (and also the status displays under some circumstances). I thought the logic was clear; however, I could only figure it out until I made a video of it. There, I could see that it did turn off, but just for the fraction of a second, and then turned on again. After realizing that the synchronization reset the flag again, the fix was also clear.
    Adafruit-GFX-Library: Added HarfBuzz
    As most readers of my posts know, I do use a modified version of the Adafruit-GFX-Library. The included fontconvert is the tool that converts TTF/OTF fonts into the C header format the GFX library uses for the keycap displays. Until now, each Unicode codepoint was rendered independently. That works fine for most Latin and CJK characters, but it falls apart for Arabic ligatures, Indic conjuncts, emoji sequences, and anything else where multiple codepoints combine into a single rendered glyph.
    HarfBuzz fixes this. You can now pass a sequence of codepoints, and the shaper figures out what glyphs they produce, handles combining and reordering, and feeds the results to FreeType for rendering. The output ends up correctly in the GFX bitmap format. This opens the door to a lot of new features. For example, I can now render country flags like Unicode country flags we know - in black and white, of course ;) Granted, it is difficult for some flags and impossible to distinguish all, but it is a nice touch. I still have to integrate that on the firmware side, but my excitement over this feature is really big. To make these flags visually appealing, there is now also an outline rendering, and all kinds of correction possibilities: Gamma, brightness, unsharp masking, ... all these new features were added with the help of AI coding. Here is the result:
    PolyHost: Breaking Free From VIA
    I already hinted that in the last post. Since QMK already split from VIA some time ago, I decided to support the dynamic layer setup with my host program. So, you can now change key assignments on the fly without VIA or VIAL (and, with that, I can update to future QMK versions more easily - no hop via the VIAL repository or adding some custom VIA stuff). I already showed it last time, but here is the basic working version: There is still work left for all the actions, like layer change etc. But I have a good feeling about it.
    PolyHost: Unit Tests
    Again, thanks to AI, I could create a big batch of new tests: device settings, key handling, overlay data, the keymap model, the KLE parser, and the Unicode cache all now have coverage.
    PolyHost: Caching Overlays and organizing in an MRU
    This is also a feature I wanted to introduce for more than a year. Instead of transferring all overlay images again and again, I just store them once and later send a mapping telling the keyboard where to read the overlay from. So the host has to remember the same mappings and has to decide when to override overlays since the storage is limited, and that is why I use an MRU to make that decision. This feature needed quite some debugging — overlays kept showing up in the wrong places,...
  • Steps towards CE Certification & Performance Improvements
    thpoll02/13/2026 at 10:09 0 comments
    I have been going back and forth for a very long time on how to get the CE certification done, and decided to join https://early.smander.com/getsmandered-round-0/ to finally get this step done. My hesitation comes from the scary price tags I heard from the CE test labs I contacted. I hope with Smander, I can achieve that without much overhead lending the experience in this process, which I don't have yet. It also feels good to follow a guideline :)  Apart from my worries around certification, I have some updates to share:
    Increased HID throughput!
    In the past, I always felt some slight delay when a new overlay gets streamed to the PolyKybd. This is the known limitation, that HID (in FullSpeed USB2.0) can only transfer one report per msec - so it is deterministic, but also very slow. As I might have mentioned, the host program, therefore, already reduces the data that needs to be transferred to the very minimum. When reading the pixmaps for the program shortcuts, the host program prepares the binary representation of all 4 methods and then chooses the one resulting in the smallest number of bytes:
    - Plain bytes (so 8 pixels per byte, as these are monochrome pixmaps), which is really only the best option if there is a repeating bit pattern over the whole display. So this is very rare, but the first thing I started with, and it is still supported.
    - RLE compressed. So basically counting how many set and cleard pixel are followed by each other. This is almost always better as the plain bytes (except for the mentioned on/off patterns)
    - Region of Interest. So, only sending the rectangle that needs to be updated. And this method comes in two flavors: RLE compressed and uncompressed.
    While sending only the region of interest (ROI) updates, the number of bytes is greatly reduced. However, a program with shortcuts on a lot of keys can still result in more than 100 HID messages that need to be sent to the PolyKybd. Next to the limitation of one HID report per msec, I also have to decompress the data (and stitch in the ROIs) on the PolyKybd, which also takes some time. For a while, I have been looking for alternatives to get some high speed communication going with QMK, but it looks like this is rather involved, and I haven't found any project doing that. It looks like it would need some rewrite of QMK's USB stack. Still, I managed to do the following:
    Activate the second core of the RP2040!
    Right, there are two cores on an RP204,0 and QMK only uses one. When starting my research on that, I could not find any reference of a QMK project doing that, so I started my own implementation with the help of the Pico-SDK. It was a rather painful process that also needed some inline assembler... Just after finishing this tricky task, I found out that there is a module called dual-rp, which lets you run some QMK callbacks on the other core. Nevertheless, I'm really happy with my own implementation as I can control exactly the stack usage of the second code (which I keep as low as 128 bytes, as I cannot waste too much RAM for that) and decide precisely what is executed. In my case, the RLE decompression! With that, I can now offload the buffer I got from HID to the second core (core1) and do not block execution, resulting in faster updates when receiving overlay data. I wish I could show you some screenshots, because I'm rather excited about this improvement. Just believe: It's great!
    Increase HID report size
    QMK uses 32 bytes HID reports and it is possible to increase that to 64 bytes while still staying USB 2.0 compliant. Increasing, however, meant to break VIA compatibility and also needed a QMK modification in the TMK core, which was unnecessary until now. All other code lives in the keyboard's "user space".
    The hesitation to give up VIA was quite significant, not because it is particularly great, but because it is convenient to update keymaps. So I, in fact, did a little GUI prototype before really...
  • Revised PCB, and other stuff
    thpoll12/27/2025 at 18:18 0 comments
    Actually, this is a year-old post that I never published. Please excuse the delay (there are always reasons...), and you may already know by now, but here is the post now:
    Even though I already have a fully working PCB (v 3.1), there was yet another revision needed!
    As mentioned in the previous post, I had to verify all components for RoHS compliance (needed for CE compliance).
    All parts used were advertised as RoHS compliant on the JLC/LCSC website. However, that website only acts as a reseller, and I have to verify the data provided by the manufacturer. Most components thankfully mention compliance in the datasheet, in some cases, I got the certificates from the manufacturer's website. One certificate was emailed to me on request! For a few parts, I couldn't find any evidence for RoHS compliance, and my emails stayed unanswered, so I had to find replacements. That is all done now!
    Apart from that, I picked a better quality (well, at least I hope) stepping voltage regulator to make sure there is no issue with that component in the certification process. This was at least some advice from my CE consultant.
    Other changes I made, since I was already at it:
     - Plated slots for the flex cable slots 🤘 (I asked for that earlier, but in the past, there was a max length limit of 6,3mm that only recently was lifted). That means the edges are smoother. There were no issues with rough edges so far, but I think it will improve the cable's lifetime.
    - Improved solder pads for the hot swap sockets of the key switches. I brought that issue up on some social media channels earlier: As it turns out, there is quite a lot of stress on the pads when inserting the key switches. One of my testers had one instance where a pad detached from the PCB. While it was possible to push the socket back in, and the pad (fortunately) stayed connected, it is far away from great:
    After some searching, I found out that this is not uncommon:
    This picture is from a keyboard PCB vendor that is even offering a repair guide to solder on some bodge wires.
    My first idea was to increase the size of the pad for higher adhesion and cover the extra area with the silkscreen. After asking around some more on social media, I got to know that adding vias and attaching the copper to a plated hole on both sides will stitch everything together even further.
    To sum up the combined solution:
    - Bigger copper areas, partially covered by the silkscreen
    - Copper on the front side connected to the backside via the plated hole
    - Additionally, stitch together copper from front and back using vias
    Alright, this is already a year old, and I'm using that PCB version ever since. With that, I can tell you that the improved footprint works well, and I am also very satisfied with the plated holes for the flex cables!
    Thanks for your ongoing interest! Thomas
  • Diffusers, Software, CE Stuff and a Video!
    thpoll12/27/2025 at 18:16 0 comments
    There was a long summer break, but I'm still working on this project. So let me give you an overview of what happened.
    RGB Light Diffusers
    Maybe these look like nothing, but they do a good job of making the RGB light more ambient. It's a bit of a pain adding these to every key, but apart from the better lighting conditions, these little pieces make the plate more dustproof, so why not add these?
    Software Refactoring
    Why? Because of inconsistencies around how different languages displayed characters that can be pressed in combination with the right ALT (Also Alt Gr) key. While this does not exist on a US keyboard, for almost every European layout, there are some extra glyphs like ¼, ½, or €, that can be pressed together with the right ALT key.
    Some examples on a Greek layout:
    I did display them already, but it was not uniform across different languages, and these required some tricks in the spreadsheet, which I addressed now. The spreadsheet looks a bit different now and contains some configuration values for displaying characters.
    Apart from that, I now added an outline (clearing pixels) when displaying overlays, so that those icons stand out a bit and are not connected to the letters/glyphs. In the code, I called that courtyard clearing. Maybe I can make that even a bit thicker. See here:
    And the same without overlays:
    CE-Certification Preparations
    In order to sell the PolyKybd in the EU, it needs to be CE-certified. For that, I do have some homework to do, for example, checking if every component I used is RoHS compliant (does not contain bad stuff like lead, halogen, etc). In case the manufacturer's datasheet does not mention conformance, I need to look for an alternative part that is certified. Another point will be the EMC (electromagnetic compatibility) test, to make sure the keyboard does not harm/interfere with its electromagnetic environment. This is a bit of a pain point, and I'm already in touch with a consultant to prepare as much as possible.
    Video!
    Apart from that, I made a video that has been uploaded to the crowd-supply YouTube channel: https://youtu.be/pXc64xxlNH0?si=81lD2oQMmqeYyKZz
    I had no idea how to start, but I wanted some camera moves around the keyboard. After a bit of meditation, I decided to abuse the kids' Lego train to do that, and I put that rig together:
    After some trial and error, I came up with a slow and steady moving contraption (the Lego locomotive is too fast), and thanks to the stabilization feature of my smartphone, I got a stable video when the camera moved. The close-ups are still not as sharp and dust-free as I wanted them to be (oh my god, I really cleaned it and got rid of grains with the compressed air spray, but..). In the end, I decided that it was good enough and I'm quite happy with the result. It is even available in 4k :) Here is another picture of the tower for the static takes:
    What Else?
    Thanks to my supporter jkolo I have some more research hardware to look at, but this is a thing for after the first release of the PolyKybd...
    Best, Thomas
  • Program Context Driven Shortcut Overlays
    thpoll05/24/2024 at 16:53 0 comments
    For a long time, I have been talking about this topic, finally, it's here and I love it!
    The missing piece was the code that loads overlays depending on the active window. The mapping is stored in a yaml file that looks like this:
    Gimp:
      overlay: overlays/gimp_template.png
      app: gimp-2.*
    Inkscape:
      overlay: overlays/inkscape_template.mods.png
      app: inkscape.*
      title: .*Inkscape
    KiCad PcbNew:
      overlay: overlays/kicad_pcb_template.png
      app: kicad.*
      title: PCB Editor
    The fields `app` and `title` are regular expressions (Python). If these match, the `overlay` will be loaded (which can be a list of entries a la [a, b, c]). At least one of the two has to be present. The first entry that matches `app` and `title` will be displayed. The name/key of the block is just used for debugging.
    The overlay can be png, gif, jpeg, bmp or whatever Qt allows to load (currently it needs an alpha channel all the time, but this restriction should go away, however, I recommend png as it has lossless compression and you can always have an alpha channel).
    The white pixels will be read and turned on. Everything else is ignored. If the name contains ".mods." like "overlays/inkscape_template.mods.png" then the code will split the RGBA channels to the following scheme:
    R: shortcuts to display with CTRL
    G: shortcuts to Display with SHIFT
    B: shortcuts to display with ALT
    A: shortcuts to display when no modifier is pressed
    In case the name contains ".combo.mods." then the shortcuts will be used for the following modifier combinations:
    R: shortcuts to display with CTRL + SHIFT
    G: shortcuts to Display with CTRL + ALT
    B: shortcuts to display with ALT + SHIFT
    A: shortcuts to display with GUI key (not yet, hopefull y soon)
    For now, I decided to not support CTRL + ALT + SHIFT as it is rather rare, but you can try to convince me (pls. write a comment).
    Save the pixel color values even if the alpha channel makes it transparent and set the format to 8-bit RGBA. If you export a png in Gimp there is a dialog to do so (always set "Save color values from transparent pixels"):
    (I first used the Gimp command `decompose` to split up to RGBA channels and before saving the command `compose` can be used again to make a single image out of it - make sure that there are no other channels present, otherwise compose will fail). You can take a look at my gimp files in the "overlays" folder as a reference.
    What's now missing, are more overlay files with all the icons needed. I now have the following:
    • Chrome
    • KiCad
    • Gimp (partially, there are really a lot!)
    • Inkscape
    • JetBrains IDEs
    • VS Code
    Would be great to have an automatic way for the icon collection...
    One More Word On Platform Support
    While my current Python library `PyWinCtl` (to make program context shortcuts possible) supports active window reporting for Windows, MacOSX and XDesktop, it lacks an implementation for Wayland.
    Today, I came across this sample https://github.com/luisbocanegra/plasma-cursor-eyes that uses a KWin script to report the cursor position to Python, changing that to report the active window should work in the same way, so I'm looking forward to that!
    Enjoy your weekend,
    Thomas
  • How The Protocol Works
    thpoll04/21/2024 at 16:46 0 comments
    To communicate with the PolyKybd, I can depend on QMK to give me HID messages, the so-called reports. All I have to do is to add the raw_hid_receive callback:
    void raw_hid_receive(uint8_t *data, uint8_t length)
    Even though the callback provides a length parameter, all reports have a fixed size of 32 bytes. For larger packages, you must slice your data on the host side and transfer it in junks.
    I started my protocol with a single identifier byte 'P' (because why not) followed by the actual command.
    For instance, P0 means: send your identification. P1 means: Send me your currently active language. The PolyKybd answers with "P0.PolyKybd Split72" or with "P1.EN". The dot after the command character means that the command has been understood (the first 2 bytes are always echoed). In contrast, the keyboard replies with "P1!" if there is a problem providing the requested data. Simple :)
    However, when supporting VIA (eg. to configure the keyboard layout via the web-browser), I have to stick to the VIA convention. Here, the first byte is already the command and there are 3 different kinds of custom commands (instead of a 'P'):
    id_custom_set_value = 0x07
    id_custom_get_value = 0x08
    id_custom_save = 0x09
    If the host sends any of these 3 reserved commands VIA will not do anything, but pass on the data to the via_custom_value_command_kb callback:
    void via_custom_value_command_kb(uint8_t *data, uint8_t length)
    So my solution is to accept either the 'P' or 0x09 (in case of VIA) and the rest can stay as it is (I’m not supporting the 2 other custom command bytes as they are meaningless for now).
    So what are the other commands next to P0 and P1?
    P2:
    Send a list of supported languages, which is a comma-separated list that might span over multiple reports:
    P2.EN,DE,FR,ES,...
    P3:
    Change the language - followed by a byte with the language to use (the index refers to the order as the languages were reported with P2)
    P4:
    Send a key overlay - followed by a byte for the keycode (so the key mapping) and another one for the modifier key (is this overlay active with Ctrl or Alt?) Since multiple reports ( 15 ) are needed for a single overlay (72x40px), there is one more byte indicating which of the 15 segments is currently sent.
    P5:
    Reset the overlay buffer (in fact just the usage buffer).
    P6:
    Followed by a byte to enable (anything != 0) or disable ( == 0) the overlays (whatever is in the current overlay buffer).
    That's it for now, but I will need more commands soon.
    Refactoring
    As I had to transfer the overlays also to the other side, I decided to refactor the communication code. It was already hard to maintain.
    It grew complex since I had issues with some of the synchronized data having toggled bits. So I added here and there mechanisms to double-check. It was never bullet-proof and once in a while, some of the displays didn't turn off (plus other small issues).
    At some point, I added a crc32 checksum to my custom messages and was surprised to see that there were failures.
    First I suspected the cable but it could be also related to the PCB layout. Or could it be something else?
    It took me ages to realize that also QMK split communication uses a checksum (crc8). But I'm not sure if that is done on all data packages. I also suspect that crc8 is not enough for longer messages. While I never saw wrong keys reported from the slave side, I could see the wrong layer information for a fracture of a second on the slave side.
    When finally refactoring, I got rid of my extra checks and just added a crc32 to every message sent. In case of an error, I just send it again. Layer information, modifiers etc. are now transferred with my own messages (and the QMK split transport for those is disabled).
    With that change, I couldn't see any issues like the ones I had before. Even after setting the transfer speed to 2 times faster, everything works fine.
    Now adding a piece of code for transferring the overlays to the other side was rather...
  • Shortcut Overlays!
    thpoll04/02/2024 at 21:30 0 comments
    Alright, so this was a bit harder than expected and I was suffering quite a bit!
    Nevertheless, I'm glad to show you the first program shortcuts that have been sent from the computer to the keyboard:
    Some of you might have noticed right away: These are GIMP shortcuts and as I found out... They are quite useful! I looked them up on a cheat sheet first. Not anymore!! 😁
    Its satisfying to see the last of the 3 use cases (next to different languages and arbitrary layouts) I originally planned, come to life.
    Of course, there is still a lot of work to be done, but as usual step by step.
    I organize the shortcuts in images with space for 90 (10x9) keys with each having the full 72x40px resolution. By intention, I decided to pick the full resolution and not just some space for the overlay as this host-driven fully graphical approach feels more powerful than the text-based rendering from the PolyKybd itself. With that, I could do a lot of customizations (different fonts, text sizes, etc...) on the fly without pre-programming it into the firmware.
    Here is my current example:
    It's not complete, but it works for my current test scenario.
    There are 3 more images needed as the shortcuts usually differ if you press CTRL, ALT or SHIFT. Maybe I put just all together into an image using the RGB channels for the version when pressing the modifiers and the alpha channel for the shortcuts without modifiers.
    So why was it so difficult? Good question. I chose Phyton for the host program, so it can be easily changed by everyone and can potentially run on every platform without the need of compilers etc. While I did some work with Python in the past, I never had to deal with image manipulation before.
    This is, where my problem started. Without getting into too much detail: It was not easy to find images libraries that work on Windows, Linux and Mac, that have no namespace collision issue a la PIL and Pillow and run together with Qt (openCV doesn't). I settled on the obvious choice of NumPy and used imageio for loading the image data instead of PIL. Maybe all the Python wizards are laughing now and could have done it during lunch break, but believe me when I tell you it took me multiple days (sure I'm not working on this full-time). Besides that setup issue, it also took me some time to prepare the data (slice the image to the individual overlays, encode them as monochrome bitmaps, transfer only entries with actual content...) so it can be understood by the keyboard and its HID protocol.
    In case you want to take a look at it: https://github.com/thpoll83/PolyKybdHost The most recent firmware will gladly accept the overlay, but not transfer it to the other side, that is still something I have to do.
    Be warned that I just tested it on Linux and it is not intended for a real user.
    And Here Is Some Other News!
    I will talk about the PolyKybd at Hackaday Europe 2024 on the 13th of April, 3pm!! The lineup is not yet announced, but I will add a link as soon as possible. Let me know if you will be there as well!
    Best, Thomas
View all 39 project logs
Rich "Forge" Mingin wrote 06/02/2024 at 01:11 point
I've been coming in from the opposite direction. I'm currently working on a Corne keyboard, which has very few keys usually (~36-40) and I was pondering screens in the keys to help me learn/remember layers. You already have the screens, and they'd make the layers a lot easier.
thpoll wrote 06/04/2024 at 04:51 point
Right, I think especially for a corne it would be really nice.
Jerry wrote 08/18/2023 at 21:37 point
Hello! I'm wondering if you have any plans of making some boards available to beta testers? I use macros to help with my work quite often, and this is something I've been looking for for a while. I'd love to help out with the project!
ryanberry261 wrote 07/19/2023 at 06:46 point
this is a very cool project. the only other recommendation for future that i would like to see is single key breakout boards. i dont know enough about he screens in resin printers but if you already have leds you might not need to have the screen self lit and just need to have a filter for the leds to display the letters. i have no idea if that would work power consumption wise
Ruslan wrote 05/01/2023 at 20:02 point
Hello
Very interesting project!
I hope you know about OLED display burnout problem. I'm afraid this might be a problem for this project. I did a burnout test a few years ago, you might be interested (there are English subtitles in the video): https://www.youtube.com/watch?v=GWOFF5tMv_A
thpoll wrote 05/02/2023 at 05:29 point
HI, yes thanks, I'm aware of that unfortunate effect. Right now, the displays turn off after a configurable timeout (currently 30sec) of inactivity to protect the displays. I was also thinking of random offsets for each key +/- 1 or 2 pixels, but haven't tried that yet. Nice test by the way!
Technology overkill wrote 04/12/2023 at 19:09 point
Do you have plans on making a full-sized version of this? Would be very interesting to see.
thpoll wrote 04/13/2023 at 08:43 point
Yes indeed, the Split keyboard will be the first platform. Any feedback and findings will go into the next version which might be (TKL) tenkeyless version. That's a full size minus the num block. The num block might be a standalone, so that you could use it as macropad or just (maybe magnetically?) attached to the TKL to get a real full size.
Technology overkill wrote 04/13/2023 at 14:43 point
Thank you! Good to know info and seems like it will be very cool when completed, I had actually been looking to make or buy something similar before, but just for a macro pad, so it’s cool to see that other people have similar ideas!
