G-EDM
The G-EDM is an electrical discharge machine that supports sinker EDM, EDM engraving, EDM drilling and Wire EDM operations. #Drahterodieren
The G-EDM is a fully automated ESP32 based three axis EDM CNC machine that supports different kinds of electrodes like brass tubes or brass sheets and is highly customizable. With the wire EDM extension it is possible to cut high precision parts out of different metals.
It uses 3D printed parts where it is possible and in the future it may support even laser and mill operations. The firmware provides many EDM specific features and is available on Github too: https://github.com/G-EDM/G-RBLevo
The G-EDM pulse generator is a modern buck converter based pulse power supply that does not need a power resistor.
All PCBs use big ground planes, feedback signal traces are fenced with via stitches and in general all ground zones on different layers are connected together with via stitches to get the best possible performance out of it.
https://www.youtube.com/@G-EDM
Contact: goblin-dev@proton.me
The G-EDM ( new video )
The final version of the control panel:
View all 77 project logs
Rich text editor
jb333 wrote 12/28/2024 at 17:05 point
Just placed my order with PCBWay for motion boards! :)
gedm-dev wrote 12/28/2024 at 17:29 point
You need the pulseboard too. Go for the EVOIII board as it is much easier to setup compared to the evoII cube.
jb333 wrote 12/29/2024 at 07:00 point
Of course! :)
I agree with you, the EVO2 cubes are works of art, but the EVO3 boards have to be a lot easier to cool! And, I appreciate the minimal number of connectors; That reduces costs a bit!
See, I'm very poor, minimum disability payment, so I can only afford to do one step at a time; Here's my plan:
1st: I bought a 38-pin ESP32-WROOM-32 with CP2102 USB Interface, a 38-pin breakout board, and rainbow wires with 2.54mm female terminals. Prices = $7, $3, and $0.20, respectively.
2nd: Installed VSCode and the platform.IO extension, then compiled and uploaded the firmware to the ESP32. Price = FREE - Yay Roland! :)
3rd: Bought a 2.4-inch iLi9341 Display with XPT2046 Touch Input. Price = $10
4th: Soldered J1 on rear of screen, then confirmed firmware and touch input, using the breakout board and rainbow wires. Price = FREE - Yay Roland! :)
5th: Ordered motionboards. Price = ~$130 for 20 PCBs.
6th: Acquiring components to solder motionboards.
7th: Order Stepper Motors to confirm motionboards, using power supply I already have.
8th: Order EVO3 pulseboards.
9th: Order components to solder pulseboards.
10th: Order Power Supplies, Wires, Case, etc.
11th: Order 3D-printed parts, including the G-EDM v1 toolhead.
12th: Order an "Aluminum-Foil" Enclosure for RF shielding.
13th: Order gantry plate. (I'm guessing that's the right term.)
14th: Order Aluminum Extrusions.
15th: Build plexiglass tank with filters.
16th: Install extraction fan.
17th: Buy dielectric fluid.
18th: Calibrate Machine and start testing!
I think that's everything! I hope to get this done sometime this Summer, if my budget and health will allow it.
gedm-dev wrote 12/29/2024 at 11:14 point
Sounds like a plan.
gedm-dev wrote 12/29/2024 at 12:03 point
PS: I still like the cube. It feels rock solid while the EVOIII board does flex easy due to the cutouts. But for me they are too much work building compared to the new board. If you want the raw cube PCBs I would give them away for free if you pay the shipment.
jb333 wrote 12/31/2024 at 23:03 point
WOW!!! That's Extremely Generous! :)
I just sent you an e-mail.
yfsnd wrote 06/11/2024 at 05:38 point
Very nice design! I am very interested. Have you shared the circuit schematics and the PCB files? Where can I check them?
Mike K wrote 03/13/2024 at 13:31 point
Amazing work. I am waiting for the PCB files to build and test one myself. I had made an edm machine in the past but my spark wasnt strong enough. Hopefully this board works in my machine.
dgourlay wrote 11/22/2023 at 22:44 point
this is GREAT!  I just saw your youtube.  Excellent work!
gedm-dev wrote 11/23/2023 at 07:41 point
Thanks. Wish it would be finished soon. But still so much to do.
H wrote 10/06/2023 at 00:59 point
Looks amazing so far! As far as I know there haven't been any other EDM makers that were willing to share their files, so thanks (even though you're not to that point yet)!
gedm-dev wrote 10/06/2023 at 02:19 point
The only thing unreleased are the PCBs and people may be surprised how simple they actually are. The ESP motion controller is jsut a breakout board that makes life easier. The pulseboard is a little more complex but still pretty basic. At some point they will be available.
H wrote 10/06/2023 at 23:51 point
Oh dam I should look more into this. I don't need the motion board since I already have individual drivers + breakout boards that are easy to wire
gedm-dev wrote 10/07/2023 at 00:34 point
The breakoutboard is very useful. It extends the SPI Mosi/MISO/CLK pins and allows to wire the display without hacking 3to1 jumper wires.
Jimmy wrote 10/04/2023 at 08:44 point
Does your GRBL version backtrack on short?
gedm-dev wrote 10/05/2023 at 07:26 point
Yes. The planner of grbl was replaced with one that can move back in history.
Piotr wrote 08/10/2023 at 00:00 point
How feedback circuit looks like? I want to build similar machine and have problem in this part.
gedm-dev wrote 08/10/2023 at 01:31 point
The feedback is just a voltage divider. that outputs between 0 and 2.8v depending on the voltage drop created. Everything else happens at software level.
joram wrote 07/12/2023 at 08:48 point
This looks interesting. Is the esp32 code already in a sharable state?
gedm-dev wrote 07/12/2023 at 12:49 point
Almost. I just need to confirm that the Y axis works too. Currently building the axis. Should be ready soon.
