Hackaday.io Hackaday.io
Sign up Log in
Long Exposure Time Camera For Night Sky
Open Night Sky Cam is a long exposure time camera based on ESP32-S3.
indreamindream
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.4k views
0 comments
6 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.4k
0
6
6
Team (1)
  • indreamindream
Join this project's team
  • OpenNightSkyCam
hardware
completed project
ESP32 arduino
This project was created on 04/03/2023 and last updated 4 years ago.
Description
* Based On ESP32-S3-Wroom-1 Module with 8MB Flash and 8MB PSRAM
* Long Exposure Time
* TF card supported by SDMMC or SdFat Library
* U-Disk Mode, USB 2.0 HighSpeed Write and Read Files
* C-Mount, also Support M12 Lens and 1.25 Inch Telescope Mount with adapter
* USB Serial Mode
Video
https://www.youtube.com/watch?v=hJdsUjagThk
https://www.youtube.com/watch?v=0wduta1NCjs
https://www.youtube.com/watch?v=QMlR2NVDoeQ
Details
Files
top.stl
Standard Tesselated Geometry - 1.04 MB - 04/03/2023 at 01:30
Download
Schematic_AR0130-DVP_38x38_2023-03-29.pdf
Adobe Portable Document Format - 83.70 kB - 04/03/2023 at 01:29
Preview
Schematic_OpenNightSkyCam_2023-03-29.pdf
Adobe Portable Document Format - 178.12 kB - 04/03/2023 at 01:29
Preview
Log In/Sign up to comment
Sign up with Github
OR
Achieve long exposure times at high frame rates using a cheap synchronized dual camera setup in time interleaved mode.
Project Owner Contributor
highrate_longexp
lars-friedrichLars Friedrich
Low budget time lapse camera with DigiSpark
absolutelyautomationAbsolutelyautomation
This tutorial helps you to create a portable camera using an ESP32-CAM running MicroPython.
Portable time-lapse camera using an ESP32-CAM
mauro-rivaMauro Riva
A battery ESP32-S3 button on the shop wall saves the last sixty seconds from nine cameras at once, over ESP-NOW and the Blue Iris JSON API.
Shopcam 2000: a button that records the past
gearscodeandfiregearscodeandfire
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Long Exposure Time Camera For Night Sky", please tell us the reason.
Send message
Remove Member
