A fairwell to IO but looking forward to IO2
A project log for The Cardboard Computer - IO is my name
My goal is a 4-bit CPU using recycled cardboard substrate and Diode Transistor Logic. This is an educational platform for me.
dr-cockroachDr. Cockroach 08/28/2018 at 19:528 Comments
Here it is August 28, 2018 and I have decided that IO has reached its limit. I have learned a lot from this project but IO has has grown to the extent that I no longer have enough room to work on any other projects and I might be moving away from the coast in the next year.
I will be saving IOs boards either for future use in IO2 or will use the parts on other projects. I wish to thank everyone here on Hackaday for their support and look forward to the same support in future projects.
There are no set plans for IO2 except that it will be much more modular in design.
Rich text editor
Martian wrote 10/08/2018 at 19:29 point
I've been on a bit of a break over the summer and I've just read this.  I'm a little saddened, this was one of my favourite projects.  It was inspirational watching IO come to life and spurred me into learning more and that helped fuel my own projects.
I hope, whether you move or not, that you do another computer project and I sincerely wish you well.
IO forever!
Dr. Cockroach wrote 10/08/2018 at 20:32 point
Hey there Martian, don't be too sad. IO2 will be starting soon enough and with some new #Light Logic  gates just to turn some heads :-D Gates without transistors, relays or vacuum tubes :-D
Martian wrote 10/08/2018 at 21:03 point
I'm looking now! wow! :)
Dave's Dev Lab wrote 08/29/2018 at 04:59 point
i kind of expected this after you cannibalized IO for your color sensor project... this type of computing project is very hard to see through to a grand finish... after a certain point you realize 98% of your goals were completed and that the last 2% isn't really worth it...
Dr. Cockroach wrote 08/29/2018 at 09:17 point
Hi Dave, Well in the end Color Cord just used a better version from IOs sequencer and IO itself was still complete but yes 98% sounds about right and it was intended to be a learning platform and indeed it was. IO2 will be better and more flexible :-)
Dr. Cockroach wrote 08/28/2018 at 21:45 point
Oh now, it's not that sad a moment, just time to move on and IO will still live again in other projects :-)
Starhawk wrote 08/29/2018 at 00:19 point
Yeah, but it still makes me feel kind of like this...
https://i.imgur.com/cbF4UVb.gif
...to see the end of it. I know the parts will get reused, but it still hits me in the feels.
