Hackaday.io Hackaday.io
Sign up Log in
Thermocouple Intrfacng with Raspberry Pi | JAVA
Reading thermocouple data on RAspberry Pi using JAVA and Pi4J with the help of MAX31855 14 bit thermocouple to digital converter.
bikash-narayan-pandaBikash Narayan Panda
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2 comments
663 followers
  • Description
  • Details
  • Files 0
  • Components 4
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 2
View Gallery
834
2
663
1
Team (1)
  • bikash-narayan-pandaBikash Narayan Panda
Join this project's team
completed project
hardware
raspberry pi pi4j java on Pi pi4j usage max31855 max31855 with raspberry pi SPi raspberry pi spi on pi
This project was created on 12/20/2016 and last updated 9 months ago.
Description
Reading thermocouple data on RAspberry Pi using JAVA and Pi4J with the help of MAX31855 14 bit thermocouple to digital converter. The MAX31855 performs cold-junction compensation and digitizes the signal from a K-, J-, N-, T-, S-, R-, or E-type thermocouple. The data is output in a signed 14-bit, SPI-compatible, read-only format. This converter resolves temperatures to 0.25°C, allows readings as high as +1800°C and as low as -270°C, and exhibits thermocouple accuracy of ±2°C for temperatures ranging from -200°C to +700°C for K-type thermocouples.
Details
Components
  • 1 × MAX31855 Semiconductors and Integrated Circuits / Misc. Semiconductors and Integrated Circuits
  • 1 × Raspberry Pi
  • 1 × K Type Thermocouple
  • 1 × SD Card with Raspbian OS for Pi
Log In/Sign up to comment
Sign up with Github
OR
Bikash Narayan Panda wrote 12/23/2016 at 13:13 • point
Gabriel.... Can you send me the formula to normalize the readings... I  hope that uses the internal temperature.....I can use that to update to the viewers on my youtube channel for more accurate readings..... By the way thanks for your response ....
Gabriel wrote 12/23/2016 at 12:19 • point
I use this chip for cold temperatures of about -80C with a K-type.... it works very well AFTER you linearize the results externally. MAXIM provided me with the formulas which where pretty simple to implement... quite accurate too!
A data acquisition box that is able to capture and graph data from analogue and digital sensors using a Raspberry Pi
Project Owner Contributor
Data Acquisition Box
kevin-kingsburyKevin Kingsbury
Turn your Raspberry Pi 3 into an Eddystone URL beacon
Raspberry Pi 3 as an Eddystone URL beacon
yamir-encarnacionYamir Encarnacion
DeviceHive is an open source IoT platform. This is about pushing data from Raspberry Pi to devicehive using Python.
Rasberry Pi : Push data from RPi to DeviceHive
alfredcAlfredC
Xively is an IoT platform. This is about pushing data from Raspberry Pi to Xively using Python.
Raspberry Pi : Push data from RPi to Xively
alfredcAlfredC
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Thermocouple Intrfacng with Raspberry Pi | JAVA ", please tell us the reason.
Send message
Remove Member
