8bit Sound For RCBus
A simple 8bit DAC, with a twist
0 followers
The core of this design was inspired by the early TRS80 "put a DAC on an I/O port and do it all in software" designs, along with the Covox and similar devices. The CPU side is a latch that then feeds into a resistor ladder and an small amplifier.
The twist is that it also has a 7474 flip flop on it. This is cleared when the port is written and can be set again by a clock pulse on an external line. Why - well if you wire the set side of it into a spare CTC channel and you plug the ready/notready signals into a Z80DMA card you get something akin to an early soundblaster for RCbus/RC2014
sound.zip
Kicad files
Zip Archive - 156.09 kB - 04/11/2023 at 12:32
Download
sound.pdf
Schematic
Adobe Portable Document Format - 83.67 kB - 04/11/2023 at 12:30
Preview
