First test on machine
05/08/2023 at 13:07 • 0 commentsFirst test on machine X-axis. Sound level is considerably improved compared to stepper drivers. There is still room for improvement. Feed-forward is not yet implemented and I haven’t tweaked tuning with machine load.
Using 8mm lead-screw with 1:4 gearing, so 4x8mm per rotation (32mm).
You may think it’s total overkill with two PnP nozzles on such large head. That is true. My goal is to make it easy to switch between PnP and CNC. Luckily OpenPNP does not require Klipper to work. It already has some pretty advanced motion features, like 3th order control etc. When up and running with OpenPNP it will be a good playground for Klipper/SimpleFOC integration or possibly make OpenPNP more capable with regard to CNC -> Gcode visuals -
Velocity Timer
04/20/2023 at 07:57 • 0 commentsfloat speed = (4 * pi / 65536) * 168000000 / ((float)timer2 - 1.0f);I was able setup a secondary (slave) timer on the encoder input. This means we time/track every rising edge on one of the encoder inputs. This can also be every encoder pulse, but we need the larger range to count.
Chat.GPT was so kind to help with the conversion to rad/s.
TIMER2 CCR1 - > 1585 Rad/s - > 20.34 TIMER2 CCR1 - > 1560 Rad/s - > 20.66 TIMER2 CCR1 - > 1621 Rad/s - > 19.88 TIMER2 CCR1 - > 1728 Rad/s - > 18.65 TIMER2 CCR1 - > 1611 Rad/s - > 20.01 TIMER2 CCR1 - > 1575 Rad/s - > 20.47 TIMER2 CCR1 - > 1550 Rad/s - > 20.80 TIMER2 CCR1 - > 1662This is the output with a 20 rad/s target using the conversion above:
Klipper integration
04/19/2023 at 18:59 • 0 commentsHi,
We are looking for BETA testers who would like to help out with SimpleFOC -> Klipper integration.
See further here: Feature request: add klipper MCU input mode - developement - SimpleFOC Community
And here : Klipper Discord
Best regards
JASEP -
TMC2660 sound-test on AZTEEG G5
04/18/2023 at 13:26 • 0 comments -
Using STM CORDIC w. SFOC.
04/18/2023 at 13:15 • 1 commentIm starting to think it would be cool to see a direct drive confiq.
This is using the CORDIC for sine and cosine calculations.
STEP vs. FOC
04/18/2023 at 02:33 • 0 commentsSo what are the real advantages when using FOC (Field Oriented Control)
When using a 16bit timer as a hardware encoder interface, That´s 65536 ticks per revolution. Or if using a 8mm screw -> 8mm / 65536 = 0,000122mm.
Less then a thou mm precision when direct driving it.
To reach e.g. 1400mm/min with a direct drive 8mm, we then need 1400mm/min / 8mm = 175 rpm or 18.32 rad/s.
We could also consider a 2:1 gearing, which will double the speed to 175 x 2 = 350 rpm.
I have started using the CORDIC for the sine/cosine calculations, and it seems fine. Perhaps a bit less vibration. The way S_FOC is using floats does not use the full potential of the CORDIC, unfortunately. It is very precise though.
100 rad/s - > 954 rpm NEMA23 FOC
04/15/2023 at 22:08 • 0 comments -
Closed Loop NEMA23
04/15/2023 at 16:56 • 0 commentsStill tuning, but this is the speed I'm getting right now. Or the highest I dare at the moment. I put a 50rad/s limit .
PANEL 1*
04/15/2023 at 02:15 • 0 comments![]()
ITS ON!
04/15/2023 at 02:14 • 0 comments![]()
Juan-Antonio Søren E.P.
