Technical Specifications
- 4 Layer PCB
- WiFi Module ESP8266 ESP-12F
- 3x Built-in signal relays ( Control PINS: R1-GPIO4, R2-GPIO5, R3-GPIO12 ) "R1 can be configured as normally open or normally closed" MAX LOAD 500mA 24V
- 2x Low-Side Switch "ULM2003" ( Control PINS: LS1-GPIO14, LS2-GPIO15 ) MAX LOAD 300mA
- 1x ADC Pin "1V Max"
- 1x ACS Pin "AC Power Detector" (Input Pin GPIO13)
- Requires 5-12V 500mA power supply
DM
teru
canique
Joel Newman
Fernando Zablah
