1Connection
Connect Arduino to power source (laptop/computer) and download Arduino IDE
2Setting up for programming
next you need to download Adafruit BusIO, Adafruit GFX Library, Adafruit NeoMatrix, and Adafruit NeoPixel
3connecting display
connect NeoPixel display wires to corresponding pins on the Arduino Uno board and connect button wire to corresponding pin on Arduino board
4Housing
Design and create housing for all of your components, leaving room for the button, displays and the board
5Programming
start by making functions for each box and the ball, then you need to program for button being pressed and making the ball move, then program the colors to be random and in the correct place, then program for the boxes of matching color to dissapear when the ball makes contact with the correct box, then once every box is gone make every box come back in so you can play for as long as you want
6Step 6
