Overall features:
- Low power and small size (45x45x10mm)
- Rechargeable and programable with Arduino
- By adding a USB port to a small solar panel you've created a simple add-on
- Can communicate via WIFI or Bluetooth
- One device can stay plugged in all the time (act as hub) while the others send updates to it (low power mode)
Back of the main board. Features:
- ESP32-S3 supports capacitance measuring directly, through the touchpad circuitry
- TP4056 charging + protection circuit
- USB C with 5.1K resistors added
- 3.3V LDO for powering everything
- Circuitry for a 1.54" E-Paper display (goes on the back)
- AHT20 IC for local air humidity and temperature measurement
- Card edge connector for easy and cheap "soil probe" PCB swap
- 2 GPIO buttons (one connected to GPIO0) and 1 status LED
Front of the main board. Features:
- Battery on-off switch
- I2C header for possible module addition
- E-Paper display
- Slim LiPo battery goes under the display. Could fit up to 4x40x30mm (usually 450-500mAh)
Soil probe. Features:
- No components and connectors added, just the bare PCB
- Cheap and easy to replace when they eventually breakdown in the soil
- Solder pads avaialble if you'd like to add a 0603 component (LED or Thermistor for soil surface temperature). Connected to GPIO through a 2K resistor
- Can be in any size and shape you'd like as long as the top matches the conector (calibration and adjustments are done in software)
Ovidiu
Ilya Egorov
Jon
Leonard Pollak
alberto nunez
