Added support for Friendly Name
07/03/2023 at 11:03 • 0 commentsIn order to be able to easily distinguish between multiple devices i have added support to give each one a "Friendly Name".
This will be used in Home Assistant instead of the hostname
Created a small solar charger "module" to extend the battery life
06/29/2023 at 10:27 • 0 commentsThis project was optimized so that even a tiny 500mAh battery would last for more than 2 weeks while sending updates over WIFI every 30 min!
With this simple add-on module the battery will slowly recharge over time while maintaining the entire project small and compact
Ovidiu
