ChatGPT for Discord
Use ChatGPT to learn how to code a ChatGPT Discord bot
Copy and paste the following text into ChatGPT to see an overview of how we're going to accomplish this project. Next, copy and paste any of the steps I've listed in this project into ChatGPT, where it will elaborate and give you the right guidance.
My goal is to create an always-on Discord ChatGPT bot in Python, running on a Raspberry Pi Zero 2, which users on my Discord can query any time. But I don't know how. So I'm turning to ChatGPT to walk me through the steps.
  • 1 × Raspberry Pi Zero 2 The computer we will use to host the bot
  • 1 × 32 GB MicroSD card The drive we will use to run the python script
  • 1 × USB cable and 5v adapter Power for the Raspberry Pi Zero 2
  • 1 × Paper mache skull Or any object to hold the Raspberry Pi Zero 2
  • 1 × MicroSD card reader For imaging the SD card on your other computer
  • 1
    Create a Discord server
    To create a Discord server, you need to open the Discord application, log in to your account, click on the "+" button, select "Create a Server", choose a name and icon, create any roles you need, create channels based on your needs, and then invite people to join your server.
  • 2
    Create a Discord bot account
    Start by creating a new bot account in the Discord Developer Portal. After you've created the account, make sure to keep track of the bot token. You'll need this token later on to authenticate your bot.
  • 3
    Set up your Raspberry Pi
    Set up your Raspberry Pi Zero 2 by using the Raspberry Pi Imager for MacOS to configure your internet network, and enable SSH with the user pi and the password pi, then install Raspberry Pi OS Lite to run headless.
View all 7 instructions
molmepogne wrote 07/26/2024 at 22:26 point
ChatGPT for Discord is good and it provide us the right answers we need, it is the best technology of this time. When I sued the services from the https://perthpressurecleaningexperts.com.au/roof-cleaning/ I saw many people are using it and finding the right solutions.
Serenakate1280 wrote 01/05/2024 at 11:07 point
Ciao e benvenuti a ChatGPT Italiano, il luogo dove le conversazioni si trasformano in esperienze straordinarie. Siamo qui per offrirti un'esperienza di scambio linguistico avanzata, completamente dedicata alla lingua italiana.
Esplora un mondo di conversazioni intelligenti su una vasta gamma di argomenti, dalla tecnologia e la cultura all'intrattenimento. https://chatgptitaliano.pro/ è progettato per offrirti interazioni online personalizzate e coinvolgenti.
ChatGPT Portugues wrote 11/23/2023 at 03:03 point
Introducing ChatGPT Português - GPTPortugues.com, your passport to boundless linguistic exploration! Brace yourself as we unlock the power of OpenAI's API to bring you an unrivaled conversational experience like never before. Are you ready to embark on a language adventure that knows no bounds?
ChatGPT Português transcends the limitations of conventional communication platforms by eliminating the need for tiresome account registration. Yes, you heard it right! Now, you can seamlessly delve into the limitless realm of ChatGPT without the hassle of remembering passwords or filling in lengthy forms. Say goodbye to those pesky barriers and say hello to unrestricted linguistic prowess!
chatgptpl.com wrote 11/08/2023 at 09:17 point
ChatGPTPL.com to zupełnie nowa strona internetowa, która umożliwia użytkownikom korzystanie z ChatGPT od OpenAI za darmo i bez konieczności rejestracji konta, a co najważniejsze - bez limitu tokenów. To jest nasz cud świata nowoczesnej technologii.
logintochatgpt4 wrote 06/08/2023 at 21:21 point
100%
wrote 05/19/2023 at 19:44 point
test
Richard Hogben wrote 04/26/2023 at 18:03 point
Is the skull required?
Mx. Jack Nelson wrote 04/26/2023 at 18:33 point
1000% ;)
