Results
Coaxial8or R3
Revision 3 closeup on sealing input and leak channel geometry.
Coaxial8or R2
Revision 2 with nozzle and holder installed.
Extrusion from 1.2mm nozzle
White around black PETG
Top: Magenta around black
Middle: White around magenta
Bottom: Yellow around magenta
Coaxial8or R0
Revision 0 without CHC Pro or holder installed
Produces colours with one side slightly darker than the other:
Transparent blue around white
White around copper
4-in-1-out Coaxial Hotend
I suspect that E-steps was twice as large as they should be.
Inspiration and/or examples of working principle
Render simulation of Cyan filament; Cyan coating of White filament; Cyan coating of Magenta coating of White filament; Magenta coating of White filament and finally Magenta filament.
Image source: https://twitter.com/i/status/1648662200544907267
Navigation
The title tag system is explained here, and the table is updated when a change occurs. Notable logs have bold L# text.
L1
[M][T] Initial design and fabrication optimization
L2
[M][T] 5 inputs were possible?!
L3
[T] 4 material + tube?
L4
[M] Center grub insert
L5
[M] Smallest possible size?
- Also possible prior art found
L6
[M] Fabrication Changes
L7
[M] Hotend digitally assembled
L8
[M] Starting on the cover
L9
[R] PCBWay still can't manufacture?
L10
[M] Metal 3D print edition
L11
[M] Asking PCBWay for a brass insert
L12
[M][R] Preparation for Uni round 2
L13
[T] Threads and feedback
L14
[M] Cooling ducts
L15
[M] Carriage Mount
L16
[P] 6028 Fans
L17
[P] All other components
L18
[P] Successful Fabrication and Assembly
L19
[T] Sealing with 2mm ball bearings?
L20
[X] No immediate leaks!
L21
[X] Looking at the state of the grub screws.
L22
[M] M4 Grub + 2mm Ball Edition
L23
[T] An Insert Like The Positron Hotend?
L24
[A] Mystery CNC Price Hike
L25
[T] Hotend hypotheticals: Off-centered inlet approach?
L26
[P][A] Outer Cover and leak detected
L27
[M] Visible indication of full grub tightness
L28
[M][T] Internally groove the heatblock-heatbreak mating surface?
L29
[M] Centrifugal-inlet design with expanding ball plugs
L30
[T][R] Dual heater zones?
L31
[M] 8 in 1 out hotend
L32
[M] Added components to 8 in 1 out hotend
L33
[T] Filament order and issue prevention strategy
L34
[A][B] PCBWay CNC fabrication costs USD$257 - $334
L35
[R] Bowden couplings, collets and compression fittings
L36
[T] Print abrasive filament without abrasion?
L37
[M] Heatsink for Unibody Coaxial Hotend
L38
[M] Finished modelling the Unibody 8-in-1-out hotend
L39
[T] Abrasive filament to smooth internal channels?
L40
[M][R] Simulation software and model optimizations
L41
[M] Thermal comparison between machined and unibody
L42
[T] Next steps
L43
[A] Details page before 11 Jan 2024
L44
[P] Nozzle-block heatbreak fabricated and simulated
L45
[T] Grub screw sleeve?
L46
[A] CNC price keeps increasing
L47
[C] Setting up Marlin Firmware
L48
[M][T] Machined 6-in-1-out not geometrically possible?
- Also talks about 8-in-1-out tweaks
L49
[X][P][T] CR600S setup and first test prints
- Tests 4-in-1-out hotend
- Thoughts on BotObjects 5-in-1-out hotend heatsinks
- Direct drive idea
- Failed due to leaks so only got 2 short prints
L50
[M] Printed Coaxial Hotend with clamp plate
L51
[B][C][M] Preparing shopping cart and Marlin
L52
[M] Slim Cover and Hotend Holder
L53
[M] 2D plate drawings
L54
[T] Directional fan and new filament strategy
L55
[P][M] Plates manufactured
L56
[M] Heatblock design optimisation
- Tip on preventing profile rotation when sweeping in Fusion 360
L57
[A] Heatblock ordered and 1mm PTFE gasket
L58
[T] Potential name: Coaxial8tor
L59
[M][A] Switch to 17HS4023 Nema17?
L60
[M] More ideal extruder mount
L61
[M] Coaxial8or logotype and test model
L62
[R] 42BYGH24S Nema17
L63
[C] Marlin M165 improvements
L64
[M] CR600S+coaxial8or logotype and numbers
L65
[P] Flat files fabricated
L66
[M] Using Fusion's renderer to simulate colours
L67
[P] Coaxial8or aluminium 3D print
- Other parts arrived:
--- DDE (BMG Clone)
--- Nema17
--- BTT EXP MOT
--- TMC2226
--- £6 400W PSU
--- Bowden couplers
L68
[P][A] Clamp face flattened, motors installed and holder attempted
L69
[M][A] Successful hotend holder and extruders installed
L70
[X][M] Heating Tests and Coaxial8or R1
L71
[M][T] Coaxial8... 4 A Budget?
- Backwards compatibility with 4-in-1-out
- Why not 6-in-1-out?
L72
[C] Push/Pull V-Tools in Marlin
L73
[A] Dryrun worked. Print powered down.
L74
[X][M] First Coaxial8or prints (single colour)
L75
[M] Removed M2 threads in Coaxial8or R1
L76
[T] More potential features for mixing extruders
L77
[X] Minimal flow rate, medium mixing, maximum leakage.
- Tests colour uniformity of 50/50 mix of two colours
L78
[M] Updated pathways and protected cartridges
L79
[B][R] Coaxial8or R1 print costs $47, and failed simulation attempt
L80
[M][T][A] R1 needs to be redesigned.
L81
[M] New coaxialising geometry
- "intent" mention from Construct3D founder
- Wall thickness analysis
L82
[B] 2pcs of Coaxial8or r1 ordered
L83
[P] Aluminium prints have powder still inside?
- and copper gasket industry
L84
[P] Tapped threads and copper gaskets cut
L85
[M] Updated holder and cover
L86
[P] Self-tapped plates
L87
[T] Micro heater on heatsink for a temperature-controlled valve?
L88
[X] Clogged Coaxial8ors
L89
[X][M] Continuing to try unclogging
L90
[T] Alternative geometry?
L91
[M] Coaxial8or r2: Tree Geometry
L92
[M] Streamlined via simulations
L93
[M] Diamond square output
L94
[X][P] Coaxial8or r2 machined and installed
L95
[P] 24V 200W cartridges
L96
[P][T] Logo and potential enhancements
L97
[X][T] Print attempt with Coaxial8or R2
L98
[X] Channel 1 and 8 leak, and aluminium foil around cartridge
L99
[M][P] Mild steel plates
L100
[M] Heatsink holder assembly
L101
[X] It's all grey!
L102
[A][T] Improved start-gcode. Marlin AutoMix colours?
L103
[X] Attempting to calibrate input shaping
L104
[M] R3 - High flow pathway geometry
L105
[T] Marlin - Retract specific extruders?
L106
[M] R3 - Heatblock modelled
L107
[X] Cross-section is a kite
L108
[A] R3 - Heatblock ordered
- And reason for sharp ring on the in/out ports
L109
[M] Metal plate hotend holder
L110
[M] Print-in-place cooling duct
L111
[M][P][T] Cover, holder, clamp plate and BMGs
L112
[P] Hotend Holder
L113
[P] Coaxial8or R3 heat-up, holder correction
L114
[M] 5mm motor holders and reversed extruders
L115
[X] SANPrinter Dual Drive Extruder can't be used in reverse
L116
[X] Test circles, leak cleanup and flow tests
L117
[M] Split-half hotend holder
L118
[X] Overtightening and undercooling
L119
[M] Leak shield and channels
L120
[X][M] Tried to print a gift for 8 years of CR600s
- Using OrcaSlicer
- Compressed HSVA colour system to define colours
L121
[A] Opaque filaments create sRGB gradients
L122
[A] Compressed HSVA workflow
L123
[A] Open sourced R3.1 on New Year 2025
L124
[P] Stainless clamp and new holder plates
L125
[A] Installed new plates
L126
[M] C8or 3.2: Streamlined grub shield
L127
[X] Scarf seams, nonlinear extrusion
L128
[R] Differential Extruder
L129
[T] Flange M6 inserts to avoid tapping stainless steel
L130
[R][M] Miniaturisation
L131
[R] Copper pin heatsink
L132
[M] Modelling for the fastest transition
L133
[R] Press fit tolerances
L134
[M] Created heatblock using outer-shell
L135
[M] Stainless print in place heatbreaks?
L136
[R] Paper found: FDM of Multiple Materials via Co-extrusion
L137
[M] Parallel printed heatbreaks?
L138
[T] Tapered heatbreaks, in-nozzle coaxialise, heatvalve concerns
- Windstorm S1 mention
L139
[T] Zirconia heatbreak?
L140
[T] Drop to 4 with coaxialiser in nozzle?
L141
[T] Dual 3-in-1-out splitters
Preface
[2024 - Jan 11 (Last Update: Nov 15)]
FFF 3D printing, in general, is looking like it is near the ceiling of possible features, but please note that this perception is coming from someone that believes that a #Liquid Laminate Lithography 3D Printer [gd0105] can be engineered into reality.
However, there was and still is a specific project that I wanted to pursue before I even owned my first printer (the late-2016 CR-10) which was to upgrade it to multi-colour. I had bought a diamond nozzle kit along with the printer, but it was so large that I never got around to mounting it and setting it up. Since then, I transitioned from a volcano heatblock to the NF THC-01 (a 3-in-1-out switching hotend).
Because I was thinking that I was going to be printing in PETG and PBT more in the future, and the THC-01 uses PTFE in its heatbreak, I decided to start designing the #Revolving Hotend [gd0012], but eventually I just decided to drop development one day; maybe the glamour of the project finally lost against the scepticism of the design. In all this time, my CR-10 has been in the longest "update cycle" to date and hasn't printed since late 2019, probably.
It also seemed like hope was lost when Deckingman, one of the few remaining hobbyist experimenters for multi-material printing, announced that he was moving on from his 6-in-1-out hotend project.
Fast forward to the start of 2023 when I'm researching the difference between MGN9 and MGN12 rails and I see this:
Me: Hmm? Why are there so many upvotes?
*Sees wall is the exact same colour throughout*
Me: They said it couldn't be done.
At the time of writing, I currently don't have a multi-material printer, and quite a few of my designs (such as #Teti [gd0022]) are dual colour prints. Conveniently, I bought loads of white filament, and it would be great to just buy 3 more spools to get any specific shade I want, such as the elusive milky green (#b2bcac).
I started the project once Nozzleboss/Heinz provided more details in his project, which was sometime in April 2023.
[2024 - Feb 20] After spending months and finally sending off the heatblock to be printed, I thought of "coaxial8or" as the name for it. Beforehand, this project was called the "Coaxial Hotend".
Also look at #Printer Repair [gd0137] for progress updates on the CR600S itself.
