The finished product
05/22/2023 at 12:28 • 0 commentsThis video shows the finished prototype and discusses its operation and future plans.
An overview of the functional design
05/15/2023 at 10:45 • 0 commentsIn this video I look at how the different boards interact and some of the design decisions made to help the intended user not get multiple triggers due to not being able to accurately control their hand movement.
- Message recordings can be different lengths and disable additional presses while playing
- A button has a repeat delay to prevent shaky fingers from pressing multiple times
- Finger held down delay prevents the message from repeating if the finger is not removed
Fully functional prototype
05/15/2023 at 10:25 • 0 commentsIn the past week, I have built up the new touch PCB, the processor PCB and the voice board as a complete system.
Initial results are that it works well, has good sensitivity with no cross-talk like the first prototype touch PCB. There may still be an issue with false activations that needs further work.
The video shows it working as a board out of the case, with some random phrases recorded, and then in the case (with some very dodgy sticking together)
Case design
05/04/2023 at 10:57 • 0 commentsHere is the case design with interchangeable finger guides
New capacitive touch PCB comparison
05/04/2023 at 09:15 • 0 commentsThis is the second revision of the capacitive touch PCB, where I have made the guard rings much thinner and not a closed loop. On the other side of the board, I have removed the ground plane from behind each capacitive touch area.
Fingers crossed it performs more reliably than the first after reading the datasheet a second time.
Side note: I am dyslexic and find reading large amounts of text extremely difficult, along with spelling correctly. As such you are likely to see numerous mistakes in my writing. I can't tell you how much I rely on #Assistivetech to help me with reading through read-aloud plugins on the computer, and spell checkers.
Prototype 1 PCB built but has sensitivity issues
05/02/2023 at 12:42 • 0 commentsThe first version of the capacitive touch board has major sensitivity issues, where it is false triggering in some areas and not triggering at all in others.
To experiment, I ground sections of the capacitive pads away as shown in the following video. This gave a significant improvement so off to PCB ways to get revision 2.
Tim
