Virtual Board.
05/09/2023 at 07:25 • 0 commentsTook some scissor hand work with the code to get it working in my app but really not bad at all.
Now I just have to figure out how to rotate the board vs the "camera".
The sensor connection really needs to be ble for an easy setup.
not my first board. + UDP
05/05/2023 at 05:07 • 0 commentsI think ble makes more sense for this, better power use and no need for a common wifi connection.
But for now I got a better wifi connection. After going through most of the wifi example folders I was about to switch to python when I found a udpclient example that works with the pico.
Much faster connection than loading a webpage.
- anyways needed a model to mirror the sensor.
- I think the wheelbite cuts can be a bit more smooth.
- and the nose/tail should be round so they don't hook on something i guess...
I haven't been able to get the mpu to work with the esp8266 nodemcu. but this circuit would nice and tiny.
I hate it.
05/02/2023 at 05:57 • 0 commentsI think I'll ditch the distance sensor for v2.
- its just annoying how much space it takes.
- with the case its 2x the weight i estimated.
maybe i'll wire it in as an addon. with its own case..
the case style should be good for something that doesn't need to be as portable...
Basic prototype.
05/01/2023 at 16:24 • 0 commentsV1 case. 2aa batteries direct.
- 44x80x30mm (38 with sensors) 94grams...case has 4 loops 1.6mm walls.
- power use was about 40 idle and 80 peak on updates. so about 30 hours per pair...
- with about 10 ints per data point plus the date, should be able to store about 1.5 minutes of data at 50hz.
- if i can use program space its more like 15minutes of data. but send out 2mB bursts might need a better connection.
tested this stl viewer demo app. will probably try to add this so I can create a Digital Board that mirrors the sensor data.
Then plotting some data might be useful once it has context.
https://github.com/dbrant/ModelViewer3D
