1Assemble the Robot
Assemble for testing
To assemble the guardian, start with the head and use four M2 screws to screw the camera with attached ribbon cable to the front half of the head. Optionally, if the green of the camera is visible from the outside, use a marker to color the camera board. Then put both parts of the head together.
Your servo probably came with mounting screws and a plastic horn for the gear. Use the screws to attach the horn to the base of the head.
Next, get your Raspberry Pi and your servo and connect the servo to the Raspberry Pi by connecting the PWM wire to pin 12, the power wire to pin 2, and the ground wire to pin 8. Then attach the head to the servo.
Next, get the three 10mm RGB LEDs ready. Attach the common cathode of each LED to a ground pin on your Raspberry Pi. Attach the wires for the red and the blue LEDs to GPIO pins.
Before continuing with assembly, you should test your components work as expected. To be able to test the components, you need to install viam-server and configure your components.
Install viam-server and connect to your robot
Go to the Viam app and create a new robot called guardian.
Go to the Setup tab of your new robot’s page and follow the steps to install viam-server on your computer.
Navigate to the Config tab of your robot’s page in the Viam app. Click on the Components subtab and navigate to the Create component menu.
- Add the board.
- Enter local for the name for your board component, select the type board, and select the pi model. Then click Create component.
- Add the camera.
- Create a camera component with the name cam, the type camera and the model webcam. Click Create Component to add the camera. In the new camera panel, click the Video Path field to reveal a drop-down populated with camera paths that have been identified on your machine. Select mmal service 16.1 (platform:bcm2835_v4l2-0).
- Add the servo.
- Create a servo component with the name servo, the type servo and the model pi. Click Create Component to add the servo. Configure the attributes by adding the name of your board, local, and the pin number of the pin on local that you connected your servo PWM wire to, 12:
{ "pin": "12", "board": "local"}Click Save config in the bottom left corner of the screen.
Test the components
Navigate to your robot’s Control tab to test your components.
Click on the servo panel and increase or decrease the servo angle to test that the servo moves.
Next, click on the board panel. The board panel allows you to get and set pin states. Set the pin states for the pins your LEDs are connected to to high to test that they light up.
Next, click on the camera panel and toggle the camera on to test that you get video from your camera.
Assemble and decorate
Now that you have tested your components, you can disconnect them again and paint and decorate your guardian and then put the rest of the guardian together. Remove the servo horn, and place one LED in the back of the Guardian head, leaving the wires hanging out behind the ribbon camera.
Then place the servo inside the Guardian body and attach the horn on the head to the servo’s gear. Carefully place the remaining two LEDs in opposite directions inside the body. Thread all the cables through the hole in the lid for the base of the guardian, and close the lid.
Use a suitable base with a hole, like a box with a hole cut into the top, to place your guardian on top of and reconnect all the wires to the Raspberry Pi.
At this point also connect the speaker to your Raspberry Pi.
Then test the components on the robot’s Control tab again to ensure everything still works.
2Detect Persons and Pets
For the guardian to be able to detect living beings, you can use this Machine Learning model. The model can detect a variety of things which you can see in the associated labels.txt file.
You can also train your own custom model based on images from your robot but the provided Machine Learning model is a good one to start with.
To use the provided Machine Learning model, copy the effdet0.tflite file and the labels.txt to your Raspberry Pi:
scp effdet0.tflite pi@guardian.local:/home/pi/effdet0.tflitescp labels.txt pi@guardian.local:/home/pi/labels.txt
Next, navigate to the Config tab of your robot’s page in the Viam app. Click on the Services subtab and navigate to the Create service menu.
- Add a ML service.
- The ML model service allows you to deploy the provided machine learning model to your robot. Create an ML model with the name mlmodel, the type mlmodel and the model tflite_cpu. Then click Create Service.
- In the new ML Model panel, select Path to Existing Model On Robot for the Deployment.
- Then specify the absolute Model Path as /home/pi/effdet0.tflite and the Label Path as /home/pi/labels.txt.
- Add a vision service.
- Next, add a detector as a vision service to be able to make use of the ML model. Create an vision service with the name detector, the type vision and the model mlmodel. Then click Create Service.
- In the new detector panel, select the mlmodel you configured in the previous step.
- Click Save config in the bottom left corner of the screen.
- Add a transform camera.
- To be able to test that the vision service is working, add a transform camera which will add bounding boxes and labels around the objects the service detects.
- Click on the Components subtab and navigate to the Create component menu. Create a transform camera with the name transform_cam, the type camera and the model transform.
- Replace the attributes JSON object with the following object which specifies the camera source that the transform camera will be using and defines a pipeline that adds the defined detector:
{"source": "cam","pipeline": [ { "type": "detections", "attributes": { "detector_name": "detector", "confidence_threshold": 0.6 } }]}- Click Save config in the bottom left corner of the screen.
Navigate to your robot’s Control tab to test the transform camera. Click on the transform camera panel and toggle the camera on, then point your camera at a person or pet to test if the vision service detects them. You should see bounding boxes with labels around different objects.
3Program the Guardian
With the guardian completely configured and the configuration tested, it’s time to make the robot guardian behave like a “real” guardian by programming the person and pet detection, lights, music, and movement.
The full code is available at the end of the tutorials.
Set up the Python environment
We are going to use Virtualenv to set up a virtual environment for this project, in order to isolate the dependencies of this project from other projects. Run the following commands in your command-line to install virtualenv, set up an environment venv and activate it:
python3 -m pip install --user virtualenvpython3 -m venv envsource env/bin/activate
Now, install the Python Viam SDK and the VLC module:
pip3 install viam-sdk python-vlc
Connect
Next, go to the Code Sample tab on your robot page and select Python.
Copy the boilerplate code. This code snippet imports all the necessary packages and sets up a connection with the Viam app in the cloud.
Next, create a file named main.py and paste the boilerplate code from the Code Sample tab of the Viam app into your file. Then, save your file.
Run the code to verify that the Viam SDK is properly installed and that the viam-server instance on your robot is live.
You can run your code by typing the following into your terminal:
python3 main.py
The program prints a list of robot resources.
On top of the packages that the code sample snippet imports, add the random and the vlc package to the imports. The top of your code should now look like this:
import asyncioimport randomimport vlcfrom viam.robot.client import RobotClientfrom viam.rpc.dial import Credentials, DialOptionsfrom viam.components.board import Boardfrom viam.components.camera import Camerafrom viam.components.servo import Servofrom viam.services.vision import VisionClientasync def connect(): creds = Credentials( type='robot-location-secret', payload='SECRET_FROM_VIAM_APP') opts = RobotClient.Options( refresh_interval=0, dial_options=DialOptions(credentials=creds) ) return await RobotClient.at_address('ADDRESS_FROM_VIAM_APP', opts)You will update the main() method later.
Lighting
Next, you’ll write the code to manage the LEDs. Underneath the connect() function, add the following class which allows you to create groups of LEDs that you can then turn on and off with one method call:
class LedGroup: def __init__(self, group): print("group") self.group = group async def led_state(self, on): for pin in self.group: await pin.set(on)If you want to test this code, change your main() method to:
async def main(): robot = await connect() local = Board.from_robot(robot, 'local') red_leds = LedGroup([ await local.gpio_pin_by_name('22'), await local.gpio_pin_by_name('24'), await local.gpio_pin_by_name('26') ]) blue_leds = LedGroup([ await local.gpio_pin_by_name('11'), await local.gpio_pin_by_name('13'), await local.gpio_pin_by_name('15') ]) await blue_leds.led_state(True)You can test the code by running:
python3 main.py
Your guardian lights up blue.
Detections
Now, you’ll add the code for the guardian to detect persons and pets. If you are building it for persons or cats or dogs, you’ll want to use Person, Dog, Cat, and, if you have a particularly teddy-bear-like dog, Teddy bear. You can also specify different ones based on the available labels in labels.txt.
Above the connect() method, add the following variable which defines the labels that you want to look for in detections:
LIVING_OBECTS = ["Person", "Dog", "Cat", "Teddy bear"]
Then, above the main() method add the following function which checks detections for living creatures as they are defined in the LIVING_OBJECTS variable.
async def check_for_living_creatures(detections): for d in detections: if d.confidence > 0.6 and d.class_name in LIVING_OBECTS: print("detected") return dIdling
Underneath the check_for_living_creatures() function, add the following function which gets images from the guardian’s camera and checks them for living creatures and if none are detected moves the servo randomly. If a creature is detected, the red LEDs will light up and music will play.
async def idle_and_check_for_living_creatures(cam, detector, servo, blue_leds, red_leds, music_player): living_creature = None while True: random_number_checks = random.randint(0, 5) if music_player.is_playing(): random_number_checks = 15 for i in range(random_number_checks): img = await cam.get_image() detections = await detector.get_detections(img) living_creature = await check_for_living_creatures(detections) if living_creature: await red_leds.led_state(True) await blue_leds.led_state(False) if not music_player.is_playing(): music_player.play() return living_creature print("START IDLE") await blue_leds.led_state(True) await red_leds.led_state(False) if music_player.is_playing(): music_player.stop() await servo.move(random.randint(0, 180))Focus
There is one last function that you need to add before you can write the full main() function and that is a function to focus on a given creature. The function calculates the center of the detected object and then checks if that center is close to the middle of the entire image. If it is not near the middle of the entire image, the function moves the servo to the left or right to attempt to center the object.
Add the following function above your main() function:
async def focus_on_creature(creature, width, servo): creature_midpoint = (creature.x_max + creature.x_min)/2 image_midpoint = width/2 center_min = image_midpoint - 0.2*image_midpoint center_max = image_midpoint + 0.2*image_midpoint movement = (image_midpoint - creature_midpoint)/image_midpoint angular_scale = 20 print("MOVE BY: ") print(int(angular_scale*movement)) servo_angle = await servo.get_position() if (creature_midpoint < center_min or creature_midpoint > center_max): servo_angle = servo_angle + int(angular_scale*movement) if servo_angle > 180: servo_angle = 180 if servo_angle < 0: servo_angle = 0 if servo_angle >= 0 and servo_angle <= 180: await servo.move(servo_angle) servo_return_value = await servo.get_position() print(f"servo get_position return value: {servo_return_value}")Main logic
The main logic for the guardian robot:
- initializes all the variables
- turns all LEDs blue
- loads a music file guardian.mp3
- runs an infinite loop where it calls the idle_and_check_for_living_creatures() function and when a creature is found calls the focus_on_creature() function
Please copy a suitable music file to the directory where your code is running and name it guardian.mp3.
Replace your main() function with the following:
async def main(): robot = await connect() local = Board.from_robot(robot, 'local') cam = Camera.from_robot(robot, "cam") img = await cam.get_image() servo = Servo.from_robot(robot, "servo") red_leds = LedGroup([ await local.gpio_pin_by_name('22'), await local.gpio_pin_by_name('24'), await local.gpio_pin_by_name('26') ]) blue_leds = LedGroup([ await local.gpio_pin_by_name('11'), await local.gpio_pin_by_name('13'), await local.gpio_pin_by_name('15') ]) await blue_leds.led_state(True) music_player = vlc.MediaPlayer("guardian.mp3") # grab Viam's vision service for the detector detector = VisionClient.from_robot(robot, "detector") while True: # move head periodically left and right until movement is spotted. living_creature = await idle_and_check_for_living_creatures(cam, detector, servo, blue_leds, red_leds, music_player) await focus_on_creature(living_creature, img.width, servo) # Don't forget to close the robot when you're done! await robot.close()if __name__ == '__main__': asyncio.run(main())Now, run the code:
python3 main.py
If everything works, your guardian should now start to idle and when it detects humans or dogs or cats turn red, start music, and focus on the detected being.
4Run the Program Automatically
One more thing. Right now, you have to run the code manually every time you want your guardian to work. You can also configure Viam to automatically run your code as a process.
To be able to run the python script from your Raspberry Pi, you need to install the Python SDK on your Raspberry Pi and copy your code onto the Raspberry Pi.
ssh into your Pi and install pip:
sudo apt install python3-pip
Create a folder guardian inside your home directory:
mkdir guardian
Then install the Viam Python SDK and the VLC module into that folder:
pip3 install --target=guardian viam-sdk python-vlc
Exit out of your connection to your pi and use scp to copy your code to your Pi into your new folder. Your hostname may be different:
scp main.py pi@guardian.local:/home/pi/guardian/main.py
Also copy your music file over:
scp guardian.mp3 pi@guardian.local:/home/pi/guardian/guardian.mp3
Now navigate to the Config tab of your robot’s page in the Viam app. Click on the Processes subtab and navigate to the Create process menu.
Enter main as the process name and click Create process.
In the new process panel, enter python3 as the executable, main.py as the argument, and the working directory of your Raspberry Pi as /home/pi/guardian. Click on Add argument.
Now your guardian starts behaving like a guardian automatically once booted!
5Next Steps
You now have a functioning guardian robot which you can use to monitor your pets or people. Or simply use to greet you when you get back to your desk.
Of course, you’re free to adapt the code to make it do something else, add more LEDs, or even train your own custom model to use.
6Full Code
Full code available at https://docs.viam.com/tutorials/projects/guardian/#full-code
Naomi Pentrel
