Since each reference card has its own revision, it doesn't make sense to call a release "revision". This is the 4th release, and it contains a mix of sheet revisions.
Sheet revisions in this release are listed below, one numbered sheet per entry.
- rev 2
- rev 3
- rev 3
- rev 3
- rev 2
- rev 3
- rev 2
- rev 2
- rev 3
- rev 3
- rev 3
- rev 3
- rev 4
- (unnumbered bonus sheet) rev 0
Index pages i through viii are "fossil revision", without a revision mark.
Changes:
- All active-low input and output pins have an inversion circle. Previously only some pins had the inversion circle. Pages affected: 4, 6, 9, 10, 11, 12, 13
- Fixed CD40110 LE pin/signal logic. It is now correctly marked active-low. Page 13.
- Fixed CD4511 LE pin/signal logic. It is now correctly marked active-low. Page 10.
- Fixed CD4543 LE pin/signal logic. It is now correctly marked active-high. Page 10.
- Added legend for the meaning of LE signals on page 10.
