![](https://cdn.hackaday.io/images/7588721684828058362.png)
What is PoE? My tough PoE development process
This board that I introduced to you is a board that I made before. There is my development history on that link.
After this project, I made the board and used it for various projects. I'm using it more conveniently and better than I thought. So I'd like to introduce this board.
![](https://cdn.hackaday.io/images/6882981684828095452.png)
The Bare board has arrived. It's a picture of the front and the back.
![](https://cdn.hackaday.io/images/652331684828138572.png)
This is what it looks like when you put it together. WIZnet's Ethernet chip and transformer are placed on the front, and Switching IC is placed on the back.
![](https://cdn.hackaday.io/images/1072581684828172157.png)
This is what it looks like with the Pico board. It's a very compact board. The additional header outputs +5V, +3.3V power. You can operate up to 8W of various applications.
![](https://cdn.hackaday.io/images/7760891684828203437.png)
The specifications of the board meet up to 8W, Mode A, Mode B, and Active PoE. The Raspberry Pi Pico is a very small MCU board. If it is used for a device, it will be a device that pursues compactness. Therefore, it is more advantageous to make the PoE board smaller in this case.
I've done some projects with this board.
![](https://cdn.hackaday.io/images/9753291684828234996.png)
Chat GPT API + Youtube Comment + Weather
WoW ! Enjoy the current weather with Picasso's painting!!
These are projects that I made using this Pico PoE board. It was very convenient to proceed with the project because it was small and simple.
![](https://cdn.hackaday.io/images/1985191684828298983.png)
![](https://cdn.hackaday.io/images/8980501684828308393.png)
The materials on this board are all open to the entire project. But I've created a board that has better voltage characteristics and smaller ones. If anyone needs the data, please let me know and I will share it.
Let's all enjoy Ethernet comfortably with PoE boards!
Hello,
I like your project and I want this project's details with all design files.
