setback
01/07/2017 at 14:26 • 0 commentsUnfortunate setback, my todler pulled the arduino off the counter and broke the screen. Replacement is on its way, but will likely be a few weeks out.
histogram time legend
01/06/2017 at 13:03 • 0 commentsthis is my first stab at the histogram time legend, hopefully, I'll have data populated one later today
Temperature Histogram
01/06/2017 at 12:57 • 0 commentsCurrently adding a histogram of sorts to the sleep screen. My goals for this are to show upper and lower limits (heat and cool set points) with a current temp trending between the two over a time span of 6-8ish hours. Also, I will show the status of the system during this time, Blue bar will indicate AC running, red bar will indicate calling for heat.
My initial thoughts were to show the current time in this display as well, but on second thought, i am going to leave this out for now. If I decide to display time, I will add a digital clock display or revisit this idea at another time.
