1External clocking of the raspberry pi pico
If you lift the crystal below the pico, then you can blast in an external 12 MHz clock. I placed an ECS-2333-120-BN-TR, and soldered a wire from the oscillator output to the top right pad of where the crystal used to be. In theory, you could distribute the 12 MHz clock around and use it for synchronous sampling.
