Hackaday.io Hackaday.io
Sign up Log in
MTester Alligator Clip Adapter
A very quick, simple and reliable component tester hack.
keri-szafirKeri Szafir
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
3 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
83
0
3
2
Team (1)
  • keri-szafirKeri Szafir
Join this project's team
ongoing project
This project was created on 06/20/2023 and last updated 3 years ago.
Description
Using a terminal block with two or three alligator clip cables for testing components that can't fit into the ZIF sockets, like TO3 transistors, large electrolytic caps, some SMT components etc. Sturdy and reliable - no fraying cables.
Details
Log In/Sign up to comment
Sign up with Github
OR
Build professional looking PCBs at home using the easy and cheap method
Project Owner Contributor
DIY Professional PCB - The easy way
singajeetsingajeet
In this tutorial, I am going to show you guys how to create a fire effect first using 4017 IC and then using an Arduino.
Arduino based tank project for kids
hulkHulk
Recreating vintage and unique hardware using modern components
LED filament based seven-segment displays
madisonMadison
Tool pouch made from hose jacket using a soldering iron
Tool pouch
cobinson-rrusoeCobinson Rrusoe
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "MTester Alligator Clip Adapter", please tell us the reason.
Send message
Remove Member
