Step by step instructions on how to build a WIFI streaming CAM with the Lambo D1 BPI-D1 board. You can use it as a security cam, check on a pet, etc etc..
This project has many other uses, the camera records video on a loop you can set from 3 min to 48 hrs on to an SDcard, you can also retrieve the video files via the WIFI secure connection.
I am working on installing a battery and a night vision module to use the camera in the dark. I will update this page as I make some more progress.
You will need the following items:
- BPI-D1 board
- AC/DC 5V 1A power adapter
- USB to micro USB cable
- BPI USB WIFI dongle 802.11n
- Windows PC/Laptop it may work with your Android device I have not tried it.
All these components can be found here http://www.tinyonesystems.com
Details
In this project I will show you how to build a live-stream network CAM using a BPI-D1 board
Will it work with any usb dongle or the only specific?
I've bought Mercusys MU6H which is more linux friendly and it doesn't work
Despite open source it is unclear for me from the docs.
From the seller it is does'r clear too
https://aliexpress.ru/item/32898026825.html?spm=a2g39.orderlist.0.0.39244aa6te361O&_ga=2.164163647.1451278067.1626633143-502718365.1621623404&_gac=1.83892331.1626527064.Cj0KCQjw_8mHBhClARIsABfFgpg7X9XUKldsF4CXAC9So0Q3qM6HkXpfVdd3qFyTpA4MaiscJVxkXhkaAl8HEALw_wcB&item_id=32898026825&sku_id=65853084294
