1What you need
For the inner flexible skirt:
- A resin 3D printer for the mold. I used a Formlab Form 3B+.
- Resin for the mold. I used Grey Pro.
- 12 5x20 threaded screws to hold together the aluminium overmold
- 10mm thick aluminium plates for the overmold. I bought 2 10x100x500 plates from Blockenstock
- Something to cut 10mm tick aluminium plates. I used the services from Decouplaser, a local metal shop
- A drill press with drill bits (diameter 5) for aluminium.
- Threading bits for aluminium. Kindly provided by a maker, Guy Mausy.
- A plastic injection machine. I used a Holipress from Holimaker
- TPU Plastic pellets. I used SEBS 90A, the recommended flex pellets from the machine builder.
For the outer rigid shell:
- A resin 3D printer. I used a Formlab Form 3B+.
- Resin for rigid parts. I used Grey Pro.
For the lenses:
- Transparent Acrylic/PMMA/Plexiglas sheets (5mm thick).
- A router. I used an Origin. A manual router should work too but it might be challenging to make accurate guides for the lens shapes.
- A groover. I made one with sheets of wood, screws, and a dremel.
For the lens clip assembly:
- A simple extrusion 3D printer. I used a Prusa MK3
- PETG or PLA filament
For assembly, you will need a silicon band to attach the left and right side of the goggles. I spent 4 EUR on swedish-style swim goggles to reuse the band that came with them. You should be able to find a similar-looking pair in any swim store online. Replacement bands can often be bought separately. -
2Get the models
It is is easy to download all the STLs, SVGs, and DXFs from our guithub repository.
It is also possible to rebuild these models from the source Python code after you install OpenSCAD and SolidPython:
$ sudo dnf install -y openscad $ pip install SolidPython $ make releaseThe resulting files will be located in the goggles-XXXX-XX-XX subdirectory.
3Print The shell
I have printed the shell successfully on the SoFAB's Formlab resin printer with both Draft and Grey Pro resin. The quality difference between the two resins is not visible but I picked Grey Pro to avoid potential problems with part durability.
I used the Formlab's slicer (Preform) with its default "magic wand" tool for orientation and support.
4Print the lens clip and assembly clip
The lens clip, and the back clip can be printed without special care on your FDM printer of choice. I recommend PETG for durability.
5Cut the lens
The starting point is a 5mm acrylic sheet that needs to be cut to produce an ellipsoid of the right size with the right profile:
The `lens.svg` included in the release contains paths that can be loaded into an Origin router and then used to cut acrylic sheets with a 3mm straight bit:1. Cut along the exterior of the inner path to 4.3mm
2. Cut along the exterior of the outer path to 5mm.
3. Use a knife and sanding paper to clean gently the sides of the lensBeware of the thickness variability of acrylic sheets: in practice, it seems significant (+/- 0.2mm) for the stock I had access to so you might need to adjust the depth of the second cut.
6Groove the lens
I considered buying a cheap lens groover that can be found on aliexpress for less than 60EUR but I ended up making one with a dremel and a couple of wood planks. I used spare oak planks I had around to support the dremel horizontally with plywood for the front face:
The front face has a couple of extra plywood pieces to be able to control the depth of the groove:
Finally, I bought a lens holder to be able to keep my fingers away from the dremel rotating bit while rotating the lens itself with the holder:
The above setup allows me to cut reliably grooves of the right depth (1mm) located at the right distance (1mm) from the lens edge.
7Print the skirt mold
The skirt mold is a two-part mold that should print easily with the magic wand default settings of PreForm. Again, I used Grey Pro resin which worked well so far.
8Make an overmold
The skirt mold you printed with your resin printer will work exactly once and die a noisy death on your first plastic injection. If you want to inject at least two skirts without printing twice the mold, and if you want to make sure that the two-part mold does not open during injection, I recommend you make or buy an overmold of the right size. I made mine out of 10mm thick aluminium sheets, as recommended by a local maker.
The dxfs for the 6 parts can be found in the release directory. I got them cut by a local metal shop, Decouplaser and my local mold expert kindly drilled and threaded the missing holes for me. The result might be a bit overkill but it worked for me.
9Inject skirts
After the overmold is assembled, the skirt mold should fit easily. I needed to sand the mold external faces to make them fit tightly within the overmold.
After injecting a couple of skirts, I noted the following:
- Make sure that the screws of the overmold are very tight to ensure proper injection without flash.
- After a couple of injections, the mold will get warmer. It will expand and will be more difficult to insert and remove from the overmold.
- Hold time for the machine and pellets I used is at 10-20s. It seems that the hold time depends on the temperature of the mold itself: decrease hold time when temperature increases to avoid extra pressure at the point where material is injected in the mold.
The skirts should need minimal post-processing: if the overmold is not sufficiently tight, you might need to remove some flash.
Mathieu Lacage
