Intro
Hello! I made a fun project this time as well!
This project is very similar to the last one, but it's been upgraded a lot!
Check out the previous project for more information!
Hardware
The configuration is very simple! All you need is a W5100S capable of Ethernet communication with Raspberry pico. I used the W5100S-PoE board that I developed. And just configure the switch circuit to press the SPI-enabled LCD and switch like last time, and that's it!
The pin setting is the same as the image above.
Ethernet Connectivity
The first thing to do is to do is to connect Ethernet. You can easily connect the Pico board to Ethernet by entering the Git below.
You can configure the computer to be a server and the Pico to be a client.
Image transfer / Display
while True:
with open("back1234.bmp", "rb") as f:
image_data = f.read()
print(image_data)
len_sent = f"LEN:{len(image_data)}".encode()
print(f"length of sent data = {len_sent}")
connectionSock.send(len_sent)
time.sleep(1)
connectionSock.send(image_data)
time.sleep(1)
Pass the BMP image that has already been created over Ethernet. (Server)
while True:
data = s.recv(MAXBUF)
if not data:
continue
if len(data):
print(len(data))
if not len_buf:
if b"LEN" in data:
len_buf = int(data.decode().split(":")[1])
print(f"length of buf = {len_buf}")
else:
buf += data
if len(buf) >= len_buf:
break
bmp_data = bytearray(buf)
with open("test.bmp", "wb") as f:
f.write(bmp_data)
f.close()
group = displayio.Group()
display.show(group)
bitmap = displayio.OnDiskBitmap("/test.bmp")
tile_grid = displayio.TileGrid(bitmap, pixel_shader=bitmap.pixel_shader)
group.append(tile_grid)
os.remove("/test.bmp")
The client connects to the server and receives the image and displays it. (Client)
Select a card
You can choose the card you want with four buttons.
while True:
pressed = button1.value + button2.value * 2 + button3.value * 2 ** 2 + button4.value * 2 ** 3
if pressed != 15:
break
s.send(f"{15 - pressed}".encode())
In the Client, click the button for the desired card number. It calculates bits by bits and sends data to the server. When you click button 1, number 1 and 2 send 2, number 3 send 4, number 4 send 8.(Client)
while True:
data = connectionSock.recv(2)
if not data:
continue
data = data.decode()
card_num: str = ''
print(f"received={data}")
if data == '1':
card_num = 'first'
elif data == '2':
card_num = 'second'
elif data == '4':
card_num = 'third'
elif data == '8':
card_num = 'fourth'
query = "4 random cards flipped on pamela colman smith rws tarot deck." \
"I picked the {} card. Please explain what this card is like. Please explain within 3 sentences".format(card_num)
print(query)
When the server receives the data, it converts the data into the desired characters. And make a string to deliver to GPT.(Server)
Chat GPT
You can easily get a Chat GPT API Key from the site below.
def Chat_GPT(api_key, query):
global answer
openai.api_key = api_key
model = "gpt-3.5-turbo"
messages = [
"role": "system",
"content": "You are the best tarotist."
"role": "user",
"content": query
response = openai.ChatCompletion.create(
model=model,
messages=messages
answer = response['choices'][0]['message']['content']
print(answer)
I assigned the following role to Chat GPT and wrote a prompt accordingly.(Server)
print(query)
The main code then combines the information about the click of a button received from the device into the prompt and forwards it to the GPT.(Server)
Dall-E-2
DALL-E 2 is an image generation tool created by OpenAI.
def dall_e2(answer):
global image_url
global...
