posted video of the robot walking
01/03/2017 at 22:51 • 0 commentsI added a video in the dropbox link where you can see the robot walking. I did this after I got the question if the robot could walk because at some point the 2 middle legs would touch the ground at the same time and the question was if it would tip over. No it doesn't the robot its legs are moving to fast for it to tip over. So I posted a video with a slowmotion video where you can see the 2 middle legs touching the ground at the same time and the robot keeps walking/crawling.
01/03/2017 at 19:56 • 0 commentsI added a video in the dropbox link. You can see the robot working and I show you how I made the robot.
removed the emergency pushbutton
01/02/2017 at 23:20 • 0 commentsI removed the emergency pushbutton. This button was to prevent the robot from demaging itself during testing. You can see the two red wires that go to the pushbutton in the pictures.
