Changes to the LCD mount
08/25/2023 at 21:47 • 0 commentsOver the time, as I was using Cyberdeck, I dropped the case, and LCD came lose. Thats not good. So, I redesigned the LCD mount, with screws.
With improved strength the LCD is more stable. I also routed the HDMI under the screen.
Major upgrade
08/25/2023 at 21:42 • 0 commentsAs I started using it, I dint really see much use of secondary screen. So, I modified cyberdeck, and added two 3 Watt speakers with an audio amplifier.
Second change I did was to get rid of some poorts, and improve the hinge mechanism.
Cracking the screen
08/07/2023 at 15:25 • 0 commentsSo my final step was to install a BNC antenna on top, and wire a USB SDR module. When trying to remove LCD to place the top of case, I cracked the screen :(
So, $90 wasted, but I was able to find a used one ( Same model ) for about $60.
Everyone in hackaday knows that Oh crap!!! moment, when you realize... Only if I was not impatient. But then I think again, is being impatient part of the hunger to do something, build something, make it happen. I dont know the answer, but I know I have broken many screens, cracked PCB's and ripped those ribbon cables. I guess you have too :)
Future upgrades
08/02/2023 at 16:22 • 0 commentsNow that I've finished the initial build, there are several enhancements I'm considering. But rather than rushing into these upgrades, I plan to start actively using the cyberdeck. This hands-on approach will allow me to identify the most valuable enhancements based on my actual usage and experience, ensuring that any updates made are practical and beneficial.
Here are a few examples of the improvements I'm considering:
- While typing, the 8bitdo game controller tends to shift or even fall off. By integrating magnets, I can secure the controller in its place.
- To make the device more energy-efficient, I'm thinking of adding buttons to switch off accessories when they're not in use. For instance, I could turn off the main and secondary displays to save power.
- I'm also considering making the GPIO pins accessible. By converting them into pushbuttons, I could program them to perform specific functions, like activating the GPS or running custom scripts, and so on.
