Soldering techniques and tips
01/02/2024 at 13:25 • 0 commentsSome tips:
- Get IPA to clean the board
- USE FLUX generously!!!!
- Tin the pads
- Clean again with IPA
- Align the FPGA and connect two corners: use left pinky to hold the chip and solder wire with index and thumb
- Very importantly: solder iron 370-400 Celsius
- and afterwards: clean with IPA again.
I got this tips from a good friend.
Announcing the A030
07/11/2023 at 09:23 • 0 commentsFinalized the schematics and the PCB
Board is currently being produced by JLCPBC.
Being lazy as I am I've decided that JLCPBC will do some of the SMD elements for 2 of the 5 boards.
