TopBodysplit2.stl
Standard Tesselated Geometry -
1.06 MB -
08/11/2023 at 15:34
Download
TopBodsplit1.stl
This joins with TopBodySplit2, it was too large to print without warping.
2.23 MB -
08/11/2023 at 15:34
Download
ButtonWasherX6.stl
53.51 kB -
08/11/2023 at 15:33
Download
ButtonX5.stl
52.92 kB -
08/11/2023 at 15:33
Download
rollersec.stl
119.22 kB -
08/11/2023 at 15:33
Download
roller.stl
21.57 kB -
08/11/2023 at 15:33
Download
Base_4_001.stl
This needs to be split into separate parts, the inside piece should be printed with honeycomb infill at 30% with no top or bottom layer to create a vent.
1.67 MB -
08/11/2023 at 15:31
Download
handle.stl
27.62 kB -
08/11/2023 at 15:31
Download
powerpanel.stl
65.65 kB -
08/11/2023 at 15:31
Download
Midsecback.stl
1022.09 kB -
08/11/2023 at 15:28
Download
Midsecfront.stl
435.83 kB -
08/11/2023 at 15:28
Download
ButtonBase.stl
141.03 kB -
08/11/2023 at 15:28
Download
grill.stl
Generic Grill Template
192.86 kB -
08/11/2023 at 15:28
Download
grill2.stl
Grill with mounting points for GPIO Header and a Pi Cam
193.59 kB -
08/11/2023 at 15:28
Download
block.stl
A spacer I glued in front of the USB and HDMI ports as the rail hits them when fully extended. Eventually I'll add these directly inside the topbod stl but didn't want to reprint it all again.
1.45 kB -
08/11/2023 at 15:28
Download
