And it boots!
08/14/2023 at 01:49 • 0 commentsA few photos I took earlier of the deck, trying to find somewhere nice but not crowded...hard in Houston when everyone's trying to beat the heat.
Battery time
08/11/2023 at 01:15 • 0 commentsBattery is running longer then i really dreamed, easily an hour to one bar. The pi is secured with m2 screws, will secure the rest of the parts with vfb tape. Someday if I decide to reprint the base so I'll modify the design to use more screws but low on plastic and have used enough filament this month.
Power
08/09/2023 at 12:45 • 0 commentsI found a battery/UPS module for the Pi made by Sunfounder that was relatively cheap. The more DIY options were going to boost the price, and I'd rather have something off the shelf if my son is going to be messing with it. Overall, it seems to eliminate my low power issues which I suspect are due to trying to power the screen over the Pi's USB port. Wiring only involves some USB cables for the most part.
I can attach the power switch to the EN and Ground terminals to kill power to the machine when it's shutdown and have some options for adding LEDs for power status and charging status at some point. I'll probably need to reprint something and add some holes to make that work, but not until a future revision.
Hack The Planet!
08/05/2023 at 21:17 • 0 commentsDone screwing it all together. Need to take care of the power cable and battery still but it's getting there!
Some lite soldering
08/05/2023 at 21:14 • 0 commentsSoldered the buttons to a piece of perf board I had with some old wire lying around....crimped the ends with some jst connectors and put heat shrink over them to keep from shorting. They really should be DuPont connectors...I should buy a set from digikey. If only I had a gift card....
I used this video as a basis to setup a pro micro so it can be programmed through the pi to customize the buttons as needed.
The wires slid under the 3d printed buttons which press the wired buttons when pushed on.
And as much as you plan and measure things...
08/02/2023 at 13:24 • 0 commentsReprinting the whole base pretty much, my dremeling out a notch janked things up pretty good. Apparently, I didn't think to leave any clearance for the display cables. @*#($%^*
Additional note to self...everything everyone says about modeling with polygons is true. Sit down and learn onShape already!
Roughing it together
07/31/2023 at 01:42 • 0 commentsBegan adding heatset inserts last night, and testing if the screws would get through the holes. I may go back through and readjust things but it's at a point of 'good enough for me' and will be made to work.
Found the warping on the base I thought I fixed with some ABS gooped on and resanded was just going to be a headache and the fit was going to be more trouble then I really have time for. Not having enough black left I found a copper colored pet-g which would get me closer to the look I was originally planning to go for anyways. Something more so resembling an Atari-2600's color scheme. I still have a few more parts to print but it's coming together nicely!
Ready, Set, Print!
07/31/2023 at 00:55 • 0 commentsI've been at this for a few weeks now, modeling took a little while to get things right...had a few reprints to do which set me back, but now in a race against the end of the contest. My Aliexpress delivery arrived and getting trying to get everything printed.
There's cheaper filament out there but I find I don't have to reprint as much with the good stuff. Keene Village Plastics has been a solid brand for me, I mostly print ABS in the Voron and it doesn't smell as bad as some of the others I've tried. It also adheres very well so long as I don't go past the edge of the heater matt. I'm using black ABS for the black parts, dark grey for the modular bay as well as one of the buttons and the power port. Love the color of the pearl sparkle copper Pet-G with the black and will be using it for the base. Have used this color combo for my Head Amame headphones and a few other things I've made over the last few years. In this case however it has a bit of the feel of an Atari 2600 color scheme.
Matthew H
