Handheld Linux Terminal [HaLiTerm]
A compact serial terminal with a built-in NanoPi Neo Air running DietPi.
This is a serial terminal with a built-in single board computer running a Linux distribution. A NanoPi Neo Air running DietPi is connected via UART to a Raspberry Pi Pico. The Pico is connected via SPI to an Adafruit RA8875 board driving an 800x480 TFT display. The remaining pins of the Pico are used to scan a 71 key matrix keyboard. A DS3231 RTC module is connected via i2c with the NanoPi. The device is powered by a 10000mAh LiPo battery providing up to 15 hours of up-time. It can be charged through a micro-USB connector. The terminal supports ASCII, Latin-1 supplement, box-drawing, block, braille and some geometric-shape characters, as well as 256 colors.
// Introduction
I wanted to build a compact handheld computer. It should be small enough to be held comfortably. While it doesn't need to be rugged, it shouldn't fall apart. It should require minimal configuration to work, so I don't have to be afraid of bricking the Linux setup and having to start from scratch.
// Features
  • Works as a handheld Linux computer or as a UART terminal
  • The NanoPi Neo Air and the terminal can be switched on and off independently
  • The NanoPi Neo Air is removable
  • 800x480 TFT display, 100 columns and 30 rows
  • WiFi connectivity
  • 71 key keyboard (caps lock is toggled by pressing the two shift keys simultaneously)
  • Usable without any configuration
  • 10000mAh LiPo Battery, 15 hours of battery life
  • Charging over Micro-USB
  • Built-in RTC
  • ASCII and limited Unicode support, 256 colors
  • 2 USB 2.0 ports
  • 16 GPIO of the NanoPi Neo Air as well as SWD and UART of the Pi Pico are accessible
  • Functioning workaround to display images
// Known issues
  • The Micro-USB on the Pico is not accessible. This is intentional, because back-powering is not addressed. The Pico could be soldered using header pins to keep the USB accessible. In this case, the power switch of the Pico must be turned off, if it is directly connected to a USB power source.
  • Connecting or disconnecting a charger interrupts the power output of the battery charging board.
  • The footprint of the NanoPi Neo Air on the PCB is slightly incorrect, but not as much that it couldn't be mounted.
  • The USB-ports are too close to each other, there isn't enough space to use them simultaneously.
terminal.uf2
Compiled Program for copying over USB to the Pico.
uf2 - 82.00 kB - 10/18/2023 at 17:59
Download
handheld-linux-terminal-src.zip
Source code for the Pico.
Zip Archive - 33.30 kB - 10/18/2023 at 17:58
Download
handheld-linux-terminal-gerber.zip
The gerber files used to order the PCB.
x-zip-compressed - 105.18 kB - 08/16/2023 at 15:58
Download
handheld-linux-terminal-backplate.zip
The design files of the back panel.
x-zip-compressed - 15.90 kB - 08/16/2023 at 15:58
Download
handheld-linux-terminal-kicad.zip
KiCad design files of the PCB.
x-zip-compressed - 467.37 kB - 08/10/2023 at 13:13
Download
View all 7 files
  • 1 × NanoPi Neo Air
  • 1 × Raspberry Pi Pico
  • 1 × Adafruit RA8875 board ADA1590
  • 1 × Adafruit 800x480 TFT display ADA1596
  • 1 × DS3231 board for Raspberry Pi It doesn’t have a part number. It's the small black one with 5 connectors: +/D/C/NC/-
View all 24 components
  • HaLiTerm mini
    Balazs08/08/2024 at 20:26 0 comments
    I have been busy trying to shrink the Handheld Linux Terminal. Beepy by SQFMI was the main inspiration. Here is the result.
  • Displaying images on the terminal
    Balazs10/18/2023 at 17:57 0 comments
    This is a crude and very slow solution to show images on the Terminal from within the Linux command line using a custom escape code and a simple Python program.
    // Usage
    path/to/primg.py -[options] path/to/image.jpg
    Options:
    -w    horizontal size (default 300)
    -h    vertical size (default 200)
    -s    max. 100x100 pixel
    -l    max. 600x400 pixel
    // primg.py (requires the pillow library)
    #!/bin/python3
    from sys import argv
    from PIL import Image
    screen_x = 300
    screen_y = 200
    # get arguments
    def get_args():
        global screen_x
        global screen_y
        for i in range(1, len(argv)):
            if argv[i] == "-w":
                w = int(argv[i+1])
                if w <= 600 and w > 0:
                    screen_x = w
            elif argv[i] == "-h":
                h = int(argv[i+1])
                if h <= 400 and h > 0:
                    screen_y = h
            elif argv[i] == "-s":
                screen_x = 100
                screen_y = 100
            elif argv[i] == "-l":
                screen_x = 600
                screen_y = 400
        return argv[-1]
    # print pixel data to stdout
    def rgb_to_stdout(image):
    #    img = image.convert(mode="RGBA")
        img_x, img_y = img.size
        print("{0}[{1};{2}z".format(chr(27), img_x, img_y), end="")
        for y in range(0, img_y):
            for x in range(0, img_x):
                r, g, b = img.getpixel((x, y))
                r = r // 8
                if r == 10:
                    r = 11
                g = g // 4
                if g == 10:
                    g = 11
                b = b // 8
                if b == 10:
                    b = 11
                print("{0}{1}{2}".format(chr(r), chr(g), chr(b)), end="")
    # rotate image if necessary
    def check_rotation(img):
        x, y = img.size
        if ((screen_x > screen_y) and (y > x)) or ((screen_x < screen_y) and (y < x)):
            return img.rotate(90, expand=True)
        else:
            return img
    # scale image
    def rescale(img):
        x, y = img.size
        scale_x = x / screen_x
        scale_y = y / screen_y
        if scale_x > scale_y:
            return img.resize((screen_x, int(y / scale_x)))
        else:
            return img.resize((int(x / scale_y), screen_y))
    # program entry
    path = get_args()
    img = Image.open(path, "r")
    img = check_rotation(img)
    img = rescale(img)
    rgb_to_stdout(img)
     // Details
    Three weeks ago the idea struck me, that I could try to send pixel values over UART from the NanoPi to the Pico and write them directly to the DDRAM of the RA8875. This solution involves a custom escape code (ESC [ (size_x ); (size_y) z) and printing the pixel RGB565 values as characters to stdout. The terminal expects exactly three times the number of pixels as characters after the escape code and keeps writing the values to the DDRAM of the RA8875 until all pixels are received. Printing values over 127 as character to stdout results in an UTF-8 encoding. Because of this, the RGB values are converted to 565 bit format before using the chr() function. After some trial and error I figured out, that print(chr(10)) didn't work, so I simply change the channel value to 11 if it would be 10.
  • Setting TERM in .bashrc and using tmux
    Balazs08/26/2023 at 12:01 0 comments
    Setting the TERM variable or the terminal size in .bashrc leads to some issues in tmux. By default, TERM is "vt220" in DietPi while using UART. This is a possible workaround that can be added to .bashrc:
    if [ $TERM = vt220 ]; then
        TERM=linux
        stty cols 100 rows 30
    fi
    This way TERM doesn't change if it was set by tmux (in my case it is "tmux-color256"). This can also be used to add lines that shouldn't be executed every time you open a new window in tmux.
  • Prototyping addon
    Balazs08/10/2023 at 12:56 0 comments
    I am still looking for inspiration for possible extension modules for this project. In the meantime I started to design a prototyping addon.
  • Getting WiringNP to work in DietPi
    Balazs08/02/2023 at 11:16 0 comments
    FreindlyElec has its own WiringPi based library called WiringNP. It compiles with several warning massages. Trying to execute "gpio readall" in DietPi returns an error massage:
    piBoardRev: Unable to determine board revision from /proc/cpuinfo
     -> Is not NanoPi based board.
     -> You may want to check:
     -> http://www.lemaker.org/
    open /sys/class/sunxi_info/sys_info failed
    While /proc/cpuinfo looks good in DietPi, sys/class/sunxi_info/sys_info doesn't exist. According to this workaround, you can redirect WiringNP to /etc/sys_info by editing WiringNP/wiringPi/boardtype_friendlyelec.c before executing ./build.
    Original:
    if (!(f = fopen("/sys/class/sunxi_info/sys_info", "r"))) {
            LOGE("open /sys/class/sunxi_info/sys_info failed.");
            return -1;
    Modified:
        if (!(f = fopen("/etc/sys_info", "r"))) {
            return -1;
    In FriendlyCore for the NanoPi NEO Air sys_info looks like this:
    sunxi_platform    : sun8iw7p1
    sunxi_secure      : normal
    sunxi_chipid      : unsupported
    sunxi_chiptype    : unsupported
    sunxi_batchno     : unsupported
    sunxi_board_id    : 2(0)
    board_manufacturer: FriendlyElec
    board_name        : FriendlyElec Nanopi-NEO-Air
    With this workaround "gpio readall" returns the expected output:
     +-----+-----+----------+------+---+-NanoPi-NEO-Air--+------+----------+-----+-----+
     | BCM | wPi |   Name   | Mode | V | Physical | V | Mode | Name     | wPi | BCM |
     |     |     |     3.3V |      |   |  1 || 2  |   |      | 5V       |     |     |
     |  12 |   8 |  GPIOA12 | ALT5 | 0 |  3 || 4  |   |      | 5V       |     |     |
     |  11 |   9 |  GPIOA11 | ALT5 | 0 |  5 || 6  |   |      | 0v       |     |     |
     | 203 |   7 |  GPIOG11 |  OFF | 0 |  7 || 8  | 0 |  OFF | GPIOG6   | 15  | 198 |
     |     |     |       0v |      |   |  9 || 10 | 0 |  OFF | GPIOG7   | 16  | 199 |
     |   0 |   0 |   GPIOA0 |  OFF | 0 | 11 || 12 | 0 |  OFF | GPIOA6   | 1   | 6   |
     |   2 |   2 |   GPIOA2 |  OFF | 0 | 13 || 14 |   |      | 0v       |     |     |
     |   3 |   3 |   GPIOA3 |  OFF | 0 | 15 || 16 | 0 |  OFF | GPIOG8   | 4   | 200 |
     |     |     |     3.3v |      |   | 17 || 18 | 0 |  OFF | GPIOG9   | 5   | 201 |
     |  64 |  12 |   GPIOC0 |  OFF | 0 | 19 || 20 |   |      | 0v       |     |     |
     |  65 |  13 |   GPIOC1 |  OFF | 0 | 21 || 22 | 0 |  OFF | GPIOA1   | 6   | 1   |
     |  66 |  14 |   GPIOC2 |  OFF | 0 | 23 || 24 | 0 |  OFF | GPIOC3   | 10  | 67  |
View all 5 project logs
  • 1
    Important:
    • The header sockets of the DS3231 must be desoldered and replaced by pins.
    • The back of the display must to be protected with isolating tape to prevent a short circuit.
    • The pins should be carefully cut as short as possible after soldering.
  • 2
    Programming the Pico
    Copy the terminal.uf2 on the Pico over USB or compile it with the Pico SDK and flash it using another Pico over SWD.
    If you want to give the Picoprobe a try, but you are having trouble getting it to work, have a look at “openocd-memo.txt”.
  • 3
    Soldering
    Soldering should be straightforward as most components are through-hole. The Pico can be soldered using either the castellated edges or header pins. The header sockets of the DS3231 must be desoldered and replaced with pins. The pogo pins can be easily soldered, if they are held in place by the NanoPi.
    After soldering I used a decent precision side cutter to carefully cut the pins as short as possible, so the battery doesn’t get damaged.
View all 6 instructions
Rich text editor
Ale o co chodzi wrote 10/23/2023 at 16:15 point
meybe add  Rotary Knob https://digiva.net/best-keyboards-with-rotary-knob/
small but very usefull when keyboard is not big.
xeddx wrote 09/01/2023 at 04:40 point
The most badass handheld
look at this post:
 https://www.reddit.com/r/linux/comments/4biamr/a_list_of_handheldpocket_linux_computers/
nerdu wrote 08/09/2023 at 06:23 point
very fat, look at ello 2 https://hackaday.io/project/9692-ello-2m  or https://hackaday.io/project/187468-ello-lc1
very good keyboard layout ! I need AltGr (right alt) for my language signs
this is better than old C.H.I.P. computer
Balazs wrote 08/09/2023 at 14:39 point
Thank you for bringing ello 2 to my attention. It is a beautiful and inspiring project. I am not nearly skilled enough to build something like it.
nerdu wrote 10/16/2023 at 10:42 point
AltGr is important
powiadam.ci wrote 08/09/2023 at 05:58 point
 10000mAh = 10Ah
Power is important if device are mobility. Why not put stepup-down for 1V-25V for any battery: AA, 18650 3.7V, etc. For example 2 independent socket for AAA and 18650 or any configuration (2x18650) or 2xAA or single AAA and 5V solar panel ;)
I have flashlight, I can replace power from flashlight to computer or from computer to flashlight.
Power similar https://soldiersystems.net/2015/05/06/owltac-a1t-endure-flashlight-kickstarter/ but better, for lipo, 1.5V, 3.7 V, 5V, or 12V from car
(BTW. How long this dev work? You are planing add small solar panel like old calculator?)
Balazs wrote 08/09/2023 at 14:36 point
I seem to have some difficulty with using appropriate SI prefixes :-)
I chose this LiPo cell because of its size. It fits perfectly under the keyboard. I did consider adding a solar panel, but it would have been a feature I never would have used, as I only use it indoors. If the battery is depleted, I can simply connect a USB power bank. It took me 4-5 months to finish the project. Right now I'm working on a breakout board for the GPIO Pins.
nerdu wrote 08/18/2023 at 06:39 point
I thing this dev is using on road or in emergency situation. Therefore power is alvays important.
Solar panel get small power but small power is needed in iddle and for keyboard, and screen
Meybe add switch to turn off screen, keyboard, decrease memory speed, turn off internet etc.
PunchNon wrote 08/09/2023 at 00:04 point
Is there an alternative for the RA8875? Because they went out of stock on Adafruit.
Thank you!
Balazs wrote 08/09/2023 at 14:17 point
Unfortunately I'm not aware of a compatible alternative.
back7.co wrote 08/03/2023 at 14:19 point
Beautiful design!  It's so tiny :)  Thank you for taking the time to document this and share the files so that others can use them too.
Tom Nardi wrote 08/03/2023 at 02:06 point
Fantastic design, and very practical. Love the portability.
nrwest wrote 08/02/2023 at 23:30 point
Nice work! Do you have more information/photos of how you made the 3D printed keycaps and labels?
Balazs wrote 08/03/2023 at 15:05 point
FreeCad and .stl model for the keycaps is in keycaps-and-labels.zip. The labels were printed with a sublimation printer (Canon Selphy CP1300). They are simply glued on the switches with some unspecified "multi glue" from a general store I had laying around.
Adrian Nicusor Aldea wrote 08/02/2023 at 12:45 point
How can I buy it ?
Balazs wrote 08/02/2023 at 17:53 point
 I haven’t considered selling it, but once you sourced the
components it is not difficult to build:)
Smeef wrote 07/30/2023 at 15:55 point
This is beautiful, I love the modular design.
Balazs wrote 07/31/2023 at 16:05 point
Thank you!
