Almost finished
08/22/2023 at 18:17 • 0 commentsI finished soldering the board and started testing it. I realized, that I have switched up pin 11 and 22. I wanted to order it in black anyway...
One step closer
08/16/2023 at 17:47 • 0 commentsThe PCBs have finally arrived today, so I was excited to start soldering. Fitting to the epic series of unlucky events I am experiencing recently, I have received 6.2k Ohm resistors instead of 390 Ohm ones. Patience is a virtue...
Update - I soldered together what I could and I am very happy that it works. The LEDs powered by 5mA are a little too bright. I need to start tweaking the resistor values.
