Faux Nixie Clock
12/22/2024 at 20:17 • 0 commentsMore Christmas presents. This time using up some early prototype boards left over from a client project (ESP32 CPU + Li-Ion battery capability)+ Adafruit 4.3" LCD displays and Li-Ion batteries from another project. I also had a little remaining orange gel sheet and some USB C breakout boards (used to supply power instead of the original main board connector).
The idea originated from my Nixie caller ID clock. I intend for them to be desk clocks that you connect to your internet via Wi-Fi and never need to set again. They also have a DS3232 RTC chip and battery backup and will run for about 8-10 hours during a power-fail. Three of the prototype boards had the DS3232 and a coin cell battery holder. But they were removed in subsequent revisions and for the fourth I had to build up a little RTC clock board with a spare DS3232 and very low quiescent current 3.3V LDO. The fourth clock doesn't have a coin cell backup but the the RTC is powered by the Li-Po directly. Since these are intended to be plugged in all the time I don't think that should be an issue.
The firmware took me a long day and a half and is a quick&dirty mash-up of the Nixie caller ID clock code, the LVGL/Web interface code from my Tiny1C thermal imaging camera and the HAL code from the original project.
I added the remainder of the USB chargers and long USB cables I bought from Amazon and the front bezel from some teak picture frames (3x4") I found there too. Cost wise these additions were a small fraction of the original cost for the prototype boards.
The teak picture frames had little cutouts inside the frame that turned out to be perfect for a 3D printed rear enclosure designed using OpenSCAD and printed using a nice sparkly black filament.
I painted the supplied bezel a mat black and taped the orange gel inside.
The clock is set initially via the web interface which is rendered by LVGL running inside an emscripten compiled webASM program. The clocks initially act as an AP (SSID: "Nixie-XXXX" where the XXXX is 4 hex digits from the MAC address). Then they can be set to act as a client to an existing Wi-Fi network where they query a NTP time server to keep their time accurate. MDNS (bonjour) is used to make finding the clock on the network easy (just browse to "nixie.local").
I plan to clean-up and port this code over to gCore and release it as open source on github when I have a little extra time.
Color wash ambient lighting Christmas present
12/17/2024 at 04:09 • 0 commentsA long time ago I designed a whole bunch of LED drivers and control systems as part of an ambient lighting system. The company I started to sell them wasn't successful but I held on to a lot of different prototypes and development boards. The system was based around a 2.4 GHz wireless protocol. A typical system might consist of a touchpad based remote control and a receiver/driver driving high-brightness or strip LEDs (all kinds, from white to RGB, RGBA and RGBW).
My partner's daughter lives in NYC and I was trying to think of something to get her for Christmas when I had the idea that her apartment needed some pretty color changing ambient lighting. So I dug through the stash.
The interesting bits include a 4-channel 350 mA constant-current driver (green PCB), a receiver/controller (white PCB) that connects to it using a flex cable, a 5V 3A supply, a HB RGB LED In a heatsink enclosure and one of the original remotes I designed.
I gutted an old halogen track light fixture and modified it to hold the LED/heatsink. It had some plastic bits that could be re-used to mount to a 3D printed base.
A bit of time with OpenSCAD resulted in a simple enclosure that was quickly - well it took 6 hours - printed. I screwed-up the location of the mounts for the driver board but it worked well enough (no-body is going to see that boo-boo).
Then I thought about the remote control. It was always a bit clunky and large because it used 4 AA batteries (one of my first embedded designs...). I decided to hack it a bit so it would run on a USB charger and remain always active.
The guts of the remote consist of a control board and a touchpad originally designed for laptops. To this I added a USB-C breakouts wired directly to the control board and threw together another 3D printed enclosure.
It all came together very well and I was really pleased with the result. The fixture can be set to any color/intensity combination (two of which can be memory presets) or set to slowly change colors on its own.
As I write this the fixture is en-route to NYC. I hope she likes it.
For this project I had everything but a cheap USB charger and 6 foot USB-C cable that I bought from Amazon. The whole project was completed over the course of three days with a lot of waiting for the 3D printer.
Late addendum
I decided to build up a couple more fixtures. For these I bought a cheap outdoor light fixture from a hardware store and re-used the globe and part of the globe mount on a 3D printed base.
Using up some old Qi chargers
11/12/2023 at 19:19 • 0 commentsI had a couple of Qi charger circuit board kits I got from Adafruit and from a client project.
A small Eureka moment ensued when I read my iPhone supported Qi charging as well as Apple's proprietary wireless charging. For some reason I still had the box the iPhone originally came in and it turned out to be a perfect dimension to hold a Qi transmitter and easily align the phone over it. A little cutting with an X-acto knife, a little hot glue and a cut piece of 0.25mm thick styrene modeling plastic and I had a bedside charger. I did have to put a piece of black electrical tape over the blue LED on the transmitter to prevent what looked like a nuclear accident from lighting up the ceiling over the night stand. I'm glad the era of Blue LED power indicators is over.
I still had another transmitter and one good receiver (the other was damaged it turns out during an experiment). So a quick OpenSCAD design made for a second 3D printed charging base. The modeling plastic is attached using double-sticky scotch tape. The design is included as one of the project files - charger_base.zip.
A couple of black plastic nuts glued over the transmitter LEDs made for very nice circular charge indicators visible through the top surface.
And then I hacked my gCore based hex calculator to include one of the wireless receivers. The Qi charger just connects to the USB 5V line and ground. It can deal with USB power being applied too so there was no need for any isolation circuitry.
The calculator also includes an accelerometer used to automatically power it on when picked up.
All-in-all a set of pretty quick little hacks with very useful results.
Faux Nixie Caller ID Clock
10/12/2023 at 19:24 • 0 commentsI live in some foothills and cell service is terrible. So I have an Ooma VOIP box as a landline and an old GE DECT wireless phone on my desk. Unfortunately most of the calls I get are spam so I decided to use a circuit I had built for weeBell testing and the great spandsp library to make a Caller ID box so I can see who is calling before picking up. Doing nothing but displaying the rare Caller ID Information seemed boring so why not make a clock too. And if one is going to make a clock, well it should be a nixie clock. Or at least a faux nixie clock and I'd get to use up an old Adafruit 3.5" 480x320 pixel touchscreen where the touchscreen part no longer worked. I even had an old picture frame to give it a faux classy look that fits in with my log house! For this project I was able to source everything from stuff I already had.
In North America, the Caller ID process works by encoding the phone number, timestamp and optionally other information like caller name with a 1200 baud FSK Bell 202 modem and transmitting that on the line after the first ring. At minimum a Caller ID box has a FSK decoder fed by an analog input. In my case I also used a pulse generated by each ring waveform to help identify a good time to start the decoding process.
The test circuit I originally built for weeBell was designed to let me safely look at the audio and ring information to debug its Caller ID generation capability. I started with the circuit diagram I found with this Arduino project and ended up modifying it slightly based on the parts I had on-hand and the desire to add a little more filtering. The schematic for my test circuit is shown below.
A typical waveform looks something like this.
The audio output is on channel 1 and the ring output is on channel 2. The actual caller ID transmission can be seen after the first ring (the analog signals associated with the ring pulse are just low frequency noise that made it through my filters).
Initial failures
The spandsp library is based around 8 kHz audio sampling so I figured I could use the 12-bit ESP32 ADC being read by the I2S peripheral to generate the audio stream. Unfortunately days of effort amounted to a very unreliable detector. I never could figure out why. I dumped the data I read, it looked OK. I tried a bunch ways to properly scale the data and remove DC offsets. Decoding would usually work the first time and then rarely after. Finally I gave up on this approach. I think for all its promise the ESP32 ADC + I2S is just problematic.
Using a real codec
Fortunately I had the AI thinker board I had originally bought when I first started playing with Bluetooth Handsfree telephony at the beginning of the weeBell project. I ported over the ES8388 audio driver to my test code and was rewarded by reliable decoding almost right away.
Now I could start on the real gadget and some quick google searching led to some great nixie tube photographs. I carefully cropped each digit and then used those as the basis for a set of bitmaps (the zero digit has a second copy with the intensity turned way down to use when leading-zero blanking for the hours display). A picture of the Russian INS1 neon indicator made a great colon (the second colon is just the original image rotated a bit). Actually 4 pictures of the colon were developed (two for it ON and two for it OFF so it can blink every second). Once again I used LVGL as my goto graphics library to provide the GUI. The LVGL website has a utility that let me take all the images and convert them to bitmaps to display on a canvas widget. The Espressif IDF has support for NTP time setting so it was easy to make a clock that would get its time using Wifi and then constantly update itself.
The final gadget resides behind the picture frame sitting on a simple 3D printed base. Although the nixie and colon images are already orange, a piece of an orange acetate lighting filter was cut and placed behind the glass to act as a filter. It works really well and the display looks even better than in these pictures. I was needing to move on from this project at this point so a sturdy mylar sheet was formed and taped to act as a dust shield. It's simply taped to the base using transparent shipping tape.
Normally the clock displays the date below the time. The Caller ID information replaces that temporarily (for a minute).
Making your own
I attached a zip file containing the IDF v4.4.4 project to this hackaday.io project (nixie_caller_id.zip) in case you'd like to make your own or use the code as the basis for your own clock. It's designed to drive the 480x320 pixel HX8357-based LCD on the Adafruit board and needs a ES8388 codec chip (which is conveniently included in the ESP32 module on the AI thinker Audio Kit board).
There are two sets of connections. One for the analog board and one for the display board. Most can be made with the existing headers on the AI thinker board but I did solder a few wires to the board.
Analog connections:
- 3.3V / GND - AI thinker expansion header
- Ring Output - GPIO21 on the AI thinker expansion header
- Analog Output - soldered to both L+R Line In audio jack (rear two pins)
Display connections:
- 5V/USB (for backlight) - Soldered to the output of the diode on the USB Power connector on the AI thinker board
- LCD CSN - GPIO19 on the AI thinker expansion header
- LCD DC - GPIO23 on the AI thinker expansion header
- LCD SPI CLK - GPIO5 on the AI thinker expansion header
- LCD SPI MOSI - GPIO18 on the AI thinker expansion header
The ES8388 inside the module is connected as follows:
- BCLK - GPIO27
- WS - GPIO25
- Data In - GPIO26
- Data Out - GPIO35
- I2S SDA - GPIO33
- I2S SCL - GPIO32
The code is using the ES8388 Line 2 inputs (through a DC-blocking capacitor).
You'll need to put in your own Wifi credentials in the components/clock/wifi.h file. Also set your timezone in the main/main.c file.
In case you want to change the GPIO assignments look in the following files (sorry I was in full-on hack mode and didn't bother with the niceties of using the sdkconfig or even a common header file):
- main/audio_task.c - ES8388 I2S signals (in the _audioInitI2S subroutine)
- components/lvgl_tft/disp_spi.h - LCD CSN, SCLK and MOSI signals
- components/lvgl_tft/hx8357.h - LCD DC signal
- components/i2c/i2c.h - ES8388 I2C signals
- main/ring_task.h - Ring signal
If you just want a faux nixie clock you can disable starting "audio_task", "cid_task" and "ring_task" in main.c.
Adapting for other Caller ID systems
The spandsp library can also decode the V23 FSK and DTMF encoding schemes used around the world. Usually these precede the first ring (or may follow a special very short first ring). It would take a little hacking but this code can support these other protocols. Probably to support a protocol that sends the information before the first ring the decoder will have to be running all them time which would require changes to audio_task, cid_task, and maybe ring_task. But to get you a little down the road, the CALLER_ID_STANDARD constant in the main/cid_task.c file sets the decoder type (ADSI_STANDARD_CLASS for Bell 202 FSK, ADSI_STANDARD_CLIP for V23 FSK and ADSI_STANDARD_CLIP_DTMF for DTMF).
Thanks for reading
Now I just need more people to call me... :-)
Big Battery Buddy
08/19/2023 at 22:03 • 0 commentsA recent camping trip left me wanting a USB Battery pack with a built-in LED light. Of course there are no end to inexpensive options available online but why buy when you can build? Are we not makers? Plus I wanted my USB Battery to have a proper on/off control and not be controlled by the current draw of things plugged into it. Fortunately upon returning home I had enough stuff laying around and Big Battery Buddy was born pretty quickly. OK, 2-3 days effort which is a lot more than just buying the damn thing. But I'm going with "it's the principle that matters".
Big Battery Buddy Features
- 6600 mA battery
- Up to 3A charge from a USB-C or Micro-B USB connector (OK, one isn't going to get 3A through the Micro-B... but it's wired in parallel to the USB-C on the dev board)
- Up to 3A 5V output (1A on a Type A USB connector, 2A on the USB-C connector)
- Soft power control with low-battery shutdown
- Battery level readout
- Built-in LED illuminator
For this project I was able to supply over 99% of the parts.
Parts List
- Maxim MAX77751 dev board. This is a 3A charger with the ability to also generate 5V @ 2A on the same path it uses for input so a USB-C connector could both source and sink power. I can't even remember why I had this board.
- My own Battery Buddy board. This harkens back to 2013 and was an early attempt at a Li-Ion battery device. It is essentially a boost converter with a low-power PIC micro-controller providing power control, battery level monitoring and low-battery cut-off.
- A 3-cell 3.7V 6600 mA Li-Ion battery (I think originally from Adafruit).
- A Sparkfun USB Type A breakout board
- A bunch of small warm-white LEDs, 0805 sized 110 ohm resistors, a switch, misc perf board, wires, screws, etc.
The Battery Buddy board provides power for the Type A USB connector and the same enable that is connected to its boost converter chip also enables the MAX77751 boost circuit. It also provides power button, battery level LEDs and low-battery cut-off functionality.
The MAX77751 is high-current charger for a single-cell Li-Ion/Lipo battery designed for USB-C connections. The thing that I found interesting about it is that it has a boost converter and can also back-drive the USB C charge input. It's also smart enough to know not to enable the boost if it is currently charging. That lets my BBB drive 5V out of the Type A connector and light the LEDs when it's charging if I want too.
Assembly
The hardest part of this project was removing all the test connectors from the MAX eval board since that thing has a lot of ground planes! I had to use a big iron. Then the Battery Buddy and USB breakout were simply double-sticky tape mounted to it and wired up. The Battery Buddy takes power from the MAX SYS output.
I wired short and heavy gauge wire between the battery pack protection PCB and the MAX board since the currents could be over 3A (I also tested the battery to make sure it could supply more than 3A).
D- is shorted to D+ on the Type A USB to signal the typical "dumb" charger to anything plugged in.
The LED board was fairly easy to wire together using a piece of a perf board. The LEDs are wired in parallel, each with its own series current limiting resistor (~16-18 mA/LED) and powered from the Battery Buddy 5V output. Somehow I damaged one LED so I ended up with a total of 9 at the end.
The most time was spent in OpenSCAD designing the case (and with calipers measuring). The source is attached and generates eight different sub-assemblies. Five of them I could print on my own printer but three of them were printed by a friend who also has transparent PLA. I count those pieces as something that had to come from elsewhere.
The case halves are screwed together with the endplates sitting in slots. The LED diffusers are glued in place and the slide switch cover just rides on the switch. The second set of printed parts went together fairly smoothly after a couple of design modifications and a little sanding... I used some shrink wrap glued to the PCBs to isolate light coming from the status LEDs on the PCBs. I'm really happy with how it turned out although even a 1.5mm thick 3D printed transparent diffuser loses a lot of light.
Thanks for reading.
Home Network DC UPS
08/17/2023 at 18:37 • 0 commentsLike many people I had a traditional AC-DC UPS supplying power to my home network. One day I awoke it it beeping away and running on battery power even though the mains power was present. And then it died. So I did what any maker might do, I optimized the repair by replacing it entirely with my own DC-DC UPS powering an Arris Cable Modem, Routerboard GigE Router/Firewall, Ethernet Hub and a Wifi Access Point.
(Don't worry - this ugly mess is in my lab where normal people never venture)
This project - now over a year old - is what led me to contemplate the "Use It UP!" campaign.
I was able to supply 100% of the parts from my own stash.
- Custom Solar MPPT Charger
- Dell 19V 3A Laptop power supply + 1000 uF electrolytic capacitor
- 12V 18 Ah Lead Acid battery
- PJRC Teensy-LC controller
- Adafruit 96x96 pixel Sharp Memory LCD breakout board
- MPT3055 N-Channel MOSFET
- Meanwell 15W Boost-Buck DC-DC converter with 12 VDC output
- Linear Tech LT3053 Buck DC-DC converter eval board with 3.3 VDC output
- Plastic Project Box, various wire and cables, protoboards, jacks, connectors and hardware
The Solar MPPT charger is a device that I designed for a client to power wildlife cameras in Asia and Africa. It has a Silicon Labs micro to implement the charge controller and a Laird smart LoRaWAN to remote control and status access.
Normally the LoRaWAN module accesses the charge controller via an I2C interface but I had a board with no LoRAWAN module. This lead me to the idea of adding a status display using the Teensy-LC and Sharp Memory LCD. A quick Arduino sketch let the Teensy read out various parameters and format them for the display.
(In reality I rarely look at it, but it has been useful - and shows the efficiency of a DC-DC UPS)
The laptop supply output voltage is just about the perfect solar panel voltage for a 12V system and the charger simply locks on to its output voltage as the MPPT setpoint. I did have to add some bulk capacitance (1000 uF) at the charger input in order for it not to crowbar when the charger starts up and has a big inrush.
A total of four DC voltages are provided to the networking devices.
- Regulated 12 VDC for the Arris Cable Modem using a Meanwell DC-DC converter.
- Unregulated battery voltage for the Routerboard Router (it has a very wide input range).
- Regulated 3.3 VDC for the Ethernet Hub using an LTC Eval board (replacing it's original AD-DC supply).
- Regulated 5 VDC for my lab's local Wifi Access Point using the charger's built in DC-DC covnerter.
The charger is capable of low-battery shut down so I kludged a wire from DC-DC enable signal coming off of its charge controller to the gate input of a beefy N-Channel MOSFET. This allows a low-side power switch for the remaining DC supplies.
(Guts of the UPS)
(Teensy-LCD and Sharp Breakout)
(LTC Eval board powering Ethernet switch)
Coda
I initially worried about the LTC board powering the Ethernet Switch since it can take a bit of power but the whole setup has been very reliable. It's capable of keeping my network alive for most of a day.
Sadly the same can't be said for the internet service itself, provided by Comcast (Xfinity). Since I live outside of my city there is at least one battery-backed up box between me and their main plant. It seems to have only enough power for about an hour of runtime when the power goes out.
Shameless Plug
In 2019 I made another smart Solar MPPT charger designed for the maker market. You can buy it on tindie. It can be the basis of a DC-DC UPS as well. Which is where the idea for this UPS came from.
