OSO-BOOK-B1.pdf
PDF of the Open Book schematic, as submitted for the Hackaday Prize.
Adobe Portable Document Format -
652.29 kB -
10/08/2023 at 04:28
Preview
OSO-BOOK-B1-01.zip
Gerber files for rev 01 of the Open Book, as submitted for the Hackaday Prize.
Zip Archive -
3.95 MB -
10/08/2023 at 03:47
Download
OSO-BOOK-B1.csv
BOM for rev 01 of the Open Book, as submitted for the Hackaday Prize. Specific part numbers are mentioned in the “Value” column; generic passives include just the component value and spec since the specific part I used doesn't really matter. Check the “Footprint” and “Notes” column to make sure you're getting the right stuff.
Comma-Separated Values -
2.90 kB -
10/08/2023 at 05:18
Download
Open Book - Sprint 5.scad
OpenSCAD sources for the Open Book enclosure as of the Hackaday Prize submission. Designed for FDM printing. Some options may not be fully implemented. NOTE: This design requires that you use either metal M2.5 screws (to bite into the plastic) or an M2.5 tap wrench if you plan to use nylon screws.
scad -
11.47 kB -
10/08/2023 at 04:31
Download
Open Book - Sprint 5 Frontplate.stl
STL file for the WIP frontplate, generated from the OpenSCAD sources above. Designed for FDM printing; the fit may not be as good with other fabrication processes.
Standard Tesselated Geometry -
155.16 kB -
10/08/2023 at 04:43
Download
Open Book - Sprint 5 Backplate.stl
STL file for the WIP backplate, generated from the OpenSCAD sources above. Designed for FDM printing; the fit may not be as good with other fabrication processes.
133.48 kB -
10/08/2023 at 04:43
Download
