Beamforming demo 8 mics
01/19/2026 at 14:04 • 0 comments8 mics beamforming on a newer version of our prototype
Test microphone with redpitaya
09/17/2023 at 15:27 • 0 commentsNew controller board still at JLPCB, so for now follows a test of one microphone from a Redpitaya which uses the same zynq7 fpga
Testing steps from Vivado
1. Generate clk for microphone (from Xilinx PLL clk generation with counters, this is required as the PLL itself does not allow slow speeds, in this case 2.4 Mhz)
2. Get the mic data to the CIC compiler ip core as decimator
3. Send decimator mic data to BRAM
4. Read BRAM from linux and put it in a socket
5. Display in python
Free hardware will make you free.
09/12/2023 at 12:26 • 0 commentsHardware files released
Microphone array (KiCAD)
https://github.com/Iari-Lab/open_acoustic_camera/tree/main/pcb/mic_array
FPGA controller (KiCAD)
https://github.com/Iari-Lab/open_acoustic_camera/tree/main/pcb/controller_zynq
State of array of microphones
09/12/2023 at 09:58 • 0 commentsTwo versions of the microphone Array have been tested, the latest version is ready for production (KiCAD files in the repo).
The second version of the controller card is being assembled, we hope to test it soon (KiCAD files in the repo).
We are using an implementation of CIC filters [1] within the FPGA (code based on Matrix Voice HDL [2])
[1] https://en.wikipedia.org/wiki/Cascaded_integrator%E2%80%93comb_filter[2] https://github.com/matrix-io/matrix-voice-fpga
The initial software tests utilize ODAS for sound source localization [3]
[3] https://github.com/introlab/odas
The license for software is GNU General Public License v3.0
The license for hardware is CERN Open Hardware Licence Version 2
Andrés Felipe Calderón de Restrepo
