Performs a continuous read/write test off Static RAM as used in arcade games using Arduino Mega
As per title, this uses an arduino to perform continuous write/read tests on 2114 static RAM as used in some arcade games pcb boards.
ino - 3.89 kB - 01/05/2017 at 03:33
x-zip-compressed - 164.48 kB - 01/05/2017 at 03:08
Acathla (Fabien)
CrazyLabz!
martin
danjovic
Yes, delete it Cancel
You are about to report the project "2114 4096 bit static RAM Tester Excerciser", please tell us the reason.
